d-series & b-series
heh, u probably thought this was another d-series versus b-series thread...
well, i just got a quick question, i wanted to know if the d-series flywheel bolts are the same as b-series flywheel bolts? would i be able to use b-series flywheel bolts on my d-series engine? thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">You can use the bolts, but not the flywheel..</TD></TR></TABLE>
i know the flywheel won't work because the b-series flywheel has an 8-bolt pattern and the d-series flywheel has a 6-bolt pattern.
how sure are u that the bolts will work??
No, but a little FYI for everyone. The del Sol flywheel even though it's a civic motor is smaller than the civic flywheel. 200 mm versus 212 mm. I found that out the hard way. Damn honda :-P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 EJ1 »</TD></TR><TR><TD CLASS="quote">
how sure are u that the bolts will work??</TD></TR></TABLE>
The bolts themselves will. Same bolt pattern.
