99 Si suspension TECH
Old Sep 10, 2001 | 10:09 PM
dynomite55's Avatar
New User
Default 99 Si suspension TECH
Does anyone know what's the best combo for the 99 Si sway bars? I think the stock is like 20or22mm in the front and 10or12mm in the rear...i'm not too sure. I want to upgrade the sways to stiffers ones..wondering if anyone has a good experience with some. Thanks.
Old Sep 11, 2001 | 04:30 AM
beretta627's Avatar
Default Re: 99 Si suspension TECH (dynomite55)
26mm in the front, 16 in the rear as I'm told.
Do you want lift-throttle oversteering? If so, 22mm seems to be the best choice. I have left my front stock and run the Mugen 22mm rear. Make sure you read up on proper installation for the rearsway, so you don't ruin your sub-frame!
Old Sep 11, 2001 | 02:11 PM
Dusty's Avatar
New User
Default Re: 99 Si suspension TECH (beretta627)
barretta waht did you do to install properly? did you do the welding.....that is the only proper way i have seen..... welding in more suport brackets on the chassis.
or the conptech setup
currently i just have the meugen 3 hole reinforcement with a nuespeed tie bar. and the (red)22mm or 21 sway bar from skunk.
also what is your idea about how freely the bar moves in the D brackets. i have been told it needs to be free moving side to side. like with grease in there to aid.....that means i need to remove the kevlar tape i have in there. any thought on this idea? or is it common knowledge?
Old Sep 11, 2001 | 07:52 PM
dynomite55's Avatar
New User
Default Re: 99 Si suspension TECH (Dusty)
I've seen comptech makes a 22mm rear sway with a tie bar. Is that one anygood? Or should I buy a 22mm sway and tie bar separate? Thanks
civexspeedy
Aug 25, 2006 02:43 PM
KtotheEK
Dec 13, 2004 11:14 AM
2khb
Apr 28, 2004 06:50 AM
Poop111444
May 23, 2003 07:36 PM
