clutch is messed up, help!!!!
Old Nov 14, 2003 | 09:46 AM
kamdog's Avatar
Default clutch is messed up, help!!!!
OK, so my clutch is messed up, I just not sure how much. I bought this car with a clutchmaster stage 3, its ruff to drive but its been fine for about a year. The other night I was driving it and all of a sudden it dosent go into gear any more. I have no pressure on the clutch any more. I was able to make it to a gas station and I checked the clutch fluid, Empty. I get some fluide and try to replace it and still no pressure. I see fluid leaking out of the slave cylinder connected to to clutch fork. Next day I get a new slave sylinder and replace it, still no pressure. Then I relize that the fork is not giving any force, and has free play.(its just floating around it there) and also it cracked!!!!. So my question is, does anyone know whats wrong with my tranny. Do I need a new clutch? I know I'll need a now slave cylinder and a new fork. Any help would be great.
Thanks ahead of time
Old Nov 14, 2003 | 09:48 AM
WiggiE's Avatar
New User
Default Re: clutch is messed up, help!!!! (kamdog)
Dumb question, did you bleed your clutch lines after replacing the slave cylinder and fluid?
Old Nov 14, 2003 | 10:12 AM
IntEGNYC's Avatar
Default Re: clutch is messed up, help!!!! (WiggiE)
you may just have heaps of air in the clutch system.
Old Nov 14, 2003 | 10:30 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">did you bleed your clutch lines after replacing the slave cylinder and fluid?</TD></TR></TABLE>
WTFINEEDBBQ
Nov 22, 2009 02:59 AM
fridayfred3p
Apr 27, 2006 03:11 PM
boosted_lude
Jan 27, 2005 04:54 PM
DrVtec99
Oct 7, 2004 07:09 PM
95excoupe
Dec 12, 2003 01:18 PM
