D15 (CRX DX) Crank Pulley vs. D16Z6, Y8, Unorthedox - Why Lightweight = Kaboom
Old Nov 14, 2003 | 09:23 AM
dohcnotec's Avatar
Default D15 (CRX DX) Crank Pulley vs. D16Z6, Y8, Unorthedox/AEM - Why Lightweight = Kaboom
If you guys have ever weighed a CRX DX Crank pulley vs. a z6 or y8, you know that it feels about 10 lbs lighter. I spoke with Mista Bone about the d15 pulley (on a d16z6) and he said it has the same problems as lightweight pulleys (as far as main bearing wear goes). Now, my question is, what makes this pulley so bad? It's OEM (Ballanced/dampered) on basically the same block/crank as a z6, so what makes it wear bearings? Is it that extra 1000 rpms the z6 revs to? wouldn't a lighter pulley go hand in hand with a lightened flywheel?
Old Nov 14, 2003 | 09:28 AM
dohcnotec's Avatar
Default Re: D15 (CRX DX) Crank Pulley vs. D16Z6, Y8, Unorthedox - Why Lightweight = Kaboom (dohcnotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">UO pulleys don't even have the correct timing marks on them.
Plus being undampened it WILL destroy you main bearings if the engine used a heavy pulley to begin with, like on a Z6 SOHC VTEC.
Stay with stock pulleys, get a lighter flywheel. You'll notice a bigger difference for about the same price.</TD></TR></TABLE>
I think he was using a d15 pulley on this motor.
Old Nov 14, 2003 | 02:41 PM
phatrick2332's Avatar
If you take ur entire rotating assembly(pistons, rods, crank, flywheel, clutch, pulley) and get it all balanced you will be just as good as balanced from factory..most likely better. but is it worth it?
Old Nov 14, 2003 | 06:09 PM
kickz's Avatar
so what your saying is that i shouldnt use a d15 crank with my REBULIT d16z6 with new bearings? ??
Old Nov 14, 2003 | 07:44 PM
dohcnotec's Avatar
Default Re: (kickz)
I think if you just throw a little mobile 1 synthetic in there, you'll be alright Seriously though, it make sense for honda to use a heavy crank pulley because a heavy weight at the end of a spinning shaft will ballance the shaft (kinda like a gyroscope), but why put such a light one on the d15? Has anybody else running a lightweight crank pulley had the same problem as Mista Bone?
Old Nov 15, 2003 | 05:56 AM
it woulnt do any harm as long as its balanced. Its just like putting a lightened flywheel on. It woulnt do any harm just becuz its lighter, It only cuz's problems when its out of balance and "wobbles". You could put a 2 pound pulley on there if u want, As long as you have everything balanced to work with that pulley.
Old Nov 15, 2003 | 12:20 PM
dohcnotec's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">it woulnt do any harm as long as its balanced. Its just like putting a lightened flywheel on. It woulnt do any harm just becuz its lighter, It only cuz's problems when its out of balance and "wobbles". You could put a 2 pound pulley on there if u want, As long as you have everything balanced to work with that pulley.</TD></TR></TABLE>
so do you think that mistabone's damage was caused by overrevving or oil starvation (or some other cause other than the pulley)
Old Nov 15, 2003 | 02:27 PM
i honestly dont believe that it was due to the pulley. If it were that out of balance i dont see how the oil grooves stayed so straight and true with that much vibration. Im thinking oil starvation.
suburban_ninja
Oct 4, 2013 10:51 AM
Jizzmaster Zero
25
Sep 17, 2007 12:25 AM
projectef
Dec 28, 2006 05:25 AM
1CiViC1
18
Nov 7, 2003 11:58 PM
