axles for b18a swap
Old Nov 14, 2003 | 08:24 AM
firstgenrex's Avatar
Default axles for b18a swap
can i use the entire drivetrain from an integra? i can get it all for FREE! so could i just put in all integra ls parts from a 90-93?
Old Nov 14, 2003 | 08:29 AM
1st-hybrid's Avatar
Default Re: axles for b18a swap (firstgenrex)
Yes you can use it all.
Old Nov 14, 2003 | 09:06 AM
is it all plug/install and play? what dizzy do i use? can i use my si ecu or maybe use an 89 teg ecu? id like to just get mounts and linkage then after that will i be ready to install it all? is it obd0 or is it 0bd1?
Old Nov 14, 2003 | 01:16 PM
Redline130's Avatar
Default Re: (firstgenrex)
I'm assuming that this is going into a 88-91 Civic or CRX. Use the distributor from the B18A, get a mount kit and shift linkage like you mentioned, use the Integra axles, and use the 90-91 Integra ecu. If your car is an Si, wiring will be even easier.
Old Nov 14, 2003 | 06:33 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firstgenrex &raquo;</TD></TR><TR><TD CLASS="quote">is it obd0 or is it 0bd1?</TD></TR></TABLE>
90-91 integra = OBD0 92-93 = OBD1
Old Nov 19, 2003 | 10:18 AM
gomer124's Avatar
Default Re: (jlicrx)
so it's imposible to use the crx axles????? i'm trying to make it work i mean it looks like they fit!!
Old Nov 19, 2003 | 11:00 AM
Deetz's Avatar
Crazy Honda Guy
No, don't use d series axels on a b series tranny. B series have an intermediate shaft and two equal lenght axels, lessening torque steer. All more expensive honda/acura use this system. Accords, preludes, integra's....
Old Nov 19, 2003 | 03:03 PM
gomer124's Avatar
Default Re: (Deetz)
yah, that's on the drivers side, what about on the passenger side, the d series axle is the exact same length as the integra one
Old Nov 19, 2003 | 05:31 PM
Jared's Avatar
Default Re: (gomer124)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gomer124 &raquo;</TD></TR><TR><TD CLASS="quote">yah, that's on the drivers side, what about on the passenger side, the d series axle is the exact same length as the integra one</TD></TR></TABLE>
wont work, wrong trans side.
Old Nov 20, 2003 | 02:33 PM
inspecta83's Avatar
Default Re: (Jared)
i have a '90 integ LS distributor if you need it.
Old Nov 21, 2003 | 04:17 AM
gomer124's Avatar
Default Re: (inspecta83)
anybody know of a cheap place that sells oem axles and intermediate driveshafts??
Old Nov 21, 2003 | 06:25 AM
slow hatch's Avatar
What Thottle and clutch cables do you use?? Thanks
Old Nov 21, 2003 | 10:57 AM
civickiller's Avatar
Default Re: (slow hatch)
90-93 throttle and clutch cable if you can get it, if not u can modify the stock clutch cable to work, i think u need a special adapter plate if you use hte si throttle cable, but the 90-93 throttle cable fits the best
Hondaboy670
Sep 21, 2017 08:35 AM
cr-rex88
26
Dec 13, 2005 12:46 AM
QWKPHKR
Jul 12, 2002 11:15 AM
QWKPHKR
Jul 11, 2002 04:03 PM
JoshM
Feb 5, 2002 04:44 AM
