GSR swap in civic Clutch/fluid/? problems
Old Nov 14, 2003 | 08:06 AM
thehatchninja's Avatar
Default GSR swap in civic Clutch/fluid/? problems
I've been having trouble getting my car into gear. I can push the clutch pedal in, and it's like it's not in at all. Sometimes i can bleed the clutch and it will be fine for an hour, week, day....whatever....it's very sporadic. But it's getting worse. I thought it was a clutch master cylinder problem since it did the same thing with the old motor. So the cluctch m/c was replaced, and now i'm suspecting the slave cylinder, but that's what was replaced on my old D16z6 with the same problem and it didn't fix it. I really don't know what to do. Any ideas.
p.s. when it's working the clutch grabs awesome, with no slippage.
Old Nov 14, 2003 | 08:10 AM
mmuller's Avatar
Mad Scientist
Default Re: GSR swap in civic Clutch/fluid/? problems (thehatchninja)
well, you're telling us that when you bleed it,it works fine for a little while..so obviously is a mc/sc problem. change the slave and go from there
Old Nov 14, 2003 | 09:11 AM
dohcnotec's Avatar
Default Re: GSR swap in civic Clutch/fluid/? problems (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">change the slave and go from there</TD></TR></TABLE>
Old Nov 14, 2003 | 11:03 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Probably slave cylinder.
See if you can source any leaks.
Old Nov 15, 2003 | 08:25 AM
Default Re: GSR swap in civic Clutch/fluid/? problems (integra707)
i just bled the clutch yesterday for like 20 minutes....i bled half of one of those big bottles of brake fluid through it. Still won't go into gear. I talked to a mechanic and he said it might be something lodged in the clutch, like a clutch spring or something like that, that's keeping it from disengaging. Cause sometimes it will work again without me bleeding it.
Old Nov 15, 2003 | 09:01 AM
also my mechanic said that since the pressure on the pedal is good then its not a m/c, s/c problem, but probably inside the trans
bigdem1civic
Transmission & Drivetrain
Mar 13, 2014 05:50 PM
WillyD
Oct 1, 2011 10:04 PM
JLSpeed
Aug 15, 2009 07:22 PM
bassman
12
Jan 26, 2007 12:01 PM
integsra
Jun 25, 2001 06:48 AM
