doin xmas shopping, not familiar with EP3's...shift boots and aftermarket shift knobs?
my friend has an ep3 civic si and i wanted to get him a skunk2 shiftknob. will he be able to use his stock shift boot? or will he have to get the jdm civic type r shift boot?
thanx, your input would be appreciated.
Modified by Jedi_Sol at 7:20 AM 11/14/2003
You really need the type-R shift boot. It is meant for that style of shift ****, where the OEM USDM shift boot is made to fit into the ring on the OEM shift ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedi_Sol »</TD></TR><TR><TD CLASS="quote">my friend has an ep3 civic si and i wanted to get him a skunk2 shiftknob. will he be able to use his stock shift boot? or will he have to get the jdm civic type r shift boot?
Just go to an Acura dealer and get this part
08999-BAK-100 for about 6.99 It is the adapter that comes with the RSX accessory ***** so you can remove the factory trim piece that clips to the **** and just have a clean round trim ring where the shift boot ends.
Hope that helps
Modified by Jedi_Sol at 7:20 AM 11/14/2003</TD></TR></TABLE>
Hope that helps
ITR#974
Jul 6, 2002 03:32 PM
