oil turning black after 500 miles
Old Nov 13, 2003 | 06:08 PM
Ludester's Avatar
Default oil turning black after 500 miles
My oil turns jet black 500 miles after I change my oil. I change the filter every oil change and I only go about 2800 miles before I change my oil. I use Valvoline high milage now, but i have tried others (castrol gtx h.m.) and the same problem occured. I dont really rip it that often maybe only a couple times a week. Is this normal? should I be concerned? Anythign I can do? I have 126k on my Lude. (94 vtec) Thanks.
Old Nov 13, 2003 | 06:40 PM
luder94-ChrisA's Avatar
Default Re: oil turning black after 500 miles (Ludester)
I wouldn't be too concerned about the black color...although I would be more concerned about using any of these "high mileage" oils. I am not a fan of the High Mileage oils. I feel like it's a marketing ploy by the oil companies. People have been making Honda & other cars last for 200,000 & more miles long before these "High Mileage" oils came out. I am very weary of what additives are really in those oils...
Old Nov 13, 2003 | 07:01 PM
rev-speed's Avatar
try mobile one / when i was runnig a ls-vtec supercharge with direct port nitrous it use to turn black after about 1000 miles the i use mobile one and it stay clean
Old Nov 13, 2003 | 07:51 PM
PhatboyNYC's Avatar
I have a 93 VTEC w/160k miles on it and I had the same thing happen with my car. I would change my oil less than every 3000 miles and the oil still came out black. I had an engine flush done and the oil comes out a lot clearer now with each change.
Old Nov 14, 2003 | 05:48 AM
Daemione's Avatar
Default Re: oil turning black after 500 miles (PhAtBoY Si)
Oil color isn't very indicative of it's condition . . . . If you're concerned about it, send off a sample to blackstone labs (http://www.blackstone-labs.com) to find out if there's any need for concern.
Old Nov 14, 2003 | 05:52 AM
LudeyKrus's Avatar
it could be b/c of blowby, couldn't it?
Old Nov 14, 2003 | 08:38 AM
577HondaPrelude's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Oil color isn't very indicative of it's condition . . . . If you're concerned about it, send off a sample to blackstone labs (http://www.blackstone-labs.com) to find out if there's any need for concern.</TD></TR></TABLE>
what he said
Old Nov 14, 2003 | 09:01 PM
ejprimo's Avatar
Default Re: (57STS)
black oil means that your oil is doing an effective job cleaning your motor.
ask your question here: http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old Nov 14, 2003 | 09:17 PM
bad-monkey's Avatar
and u don't need to change your oil every 3000 miles if you're driving normally. every 7500 is fine.
aspire
63
Feb 14, 2011 10:17 AM
meanshyguy
Mar 10, 2009 05:07 AM
alotawatts
Nov 27, 2004 12:01 PM
whitelightning
Aug 13, 2004 03:26 AM
HX_Guy
Jan 21, 2002 05:44 PM
