mpfi swap- cranks but no start.
Old Nov 13, 2003 | 05:03 PM
W0oT's Avatar
Banned
Default mpfi swap- cranks but no start.
ok just finished my mpfi swap, i repinned everything, added the dizzy wires, swapped and added ecu wires, made my own subharness, everything's soldered and shrink wrapped. i think the battery might be the prob but not sure, motor cranks but won't fire, i'm brining a charger and a jump pack to try and remidy the problem. does the 2 wires for the dizzy have to be shielded? could that be the problem, because there by themselves in there own lume untill you hit go to the firewall where it meets up w/ the injector wires. i'm gonna triple check everything tonight, there's fresh front main seal, water pump, dizzy cap, rotor, plugs, pcv, fuel filter, banjo washers, clutch and flywheel are new from a 91, new ground cable from rad support to valvecover, new valve cover gasket, everything basicly but internals. i've done my own sr20det swap in a s13 240sx, and a jdm obd0 b16 in my 91 si, and on my si it was a ground but that just caused it not to turn over at all, checked grounds, guess i'm gonna have to check for fuel and spark now.... any suggestions would help. btw it's a 89 civic dx/pm6 ecu/89 d16a6.
Old Nov 13, 2003 | 05:20 PM
Redline130's Avatar
Default Re: mpfi swap- cranks but no start. (Nismo240sx1)
Yeah, check to see if you have fuel and spark and go from there. Also, make sure you didn't mix up the two white wires at the distributor. I know that if they are reversed, that will produce a no start situation.
Old Nov 13, 2003 | 05:23 PM
W0oT's Avatar
Banned
Default Re: mpfi swap- cranks but no start. (Redline130)
it could be the wires at the distributor i agree, that was another thing i was gonna try, wish there colors didn't bleech out, there both white now it does crank though......
so tomarrow, check:
grounds
check spark
check fuel
swap dizzy wires
check wires for correct connection.
Old Nov 13, 2003 | 05:25 PM
type Gendy's Avatar
I would just double check the grounds, make sure they are goodt. IF you painted the valve cover it might not be making a good contact.
Old Nov 13, 2003 | 07:17 PM
HatchBox's Avatar
Skoobie no more...
Default Re: mpfi swap- cranks but no start. (sick hatchem)
my guess is those 2 white wires on the dizzy...check them first. good luck
Old Nov 13, 2003 | 07:22 PM
W0oT's Avatar
Banned
Default Re: mpfi swap- cranks but no start. (ind3ciso)
wonderfull, good idea's i'm definately gonna try them all, anyone else?
Old Nov 13, 2003 | 07:29 PM
RuthlessEF-9's Avatar
yeah i agree its the two white wires that are the problems most of the time
Old Nov 13, 2003 | 10:31 PM
Cm91h22a's Avatar
check the grounds that come out of the engine harness and go to the thermostat housing
Old Nov 14, 2003 | 01:26 PM
W0oT's Avatar
Banned
Default Re: mpfi swap- cranks but no start. (Cm91h22a)
ok so i checked and cleaned up my grounds, still no start, swapped 2 white wires at dizzy and still no start, i can smell gas so i suspect that i'm getting fuel, gonna check for spark now.... my only question is the car has not started, and the ecu is telling me there's a code 10 (IAT) i might have mixed it up w/ the iacv so i swapped them and still no luck, the car is closer to starting but it only pops a little every couple of ignition try's.... any idea's?
Old Nov 14, 2003 | 01:30 PM
blackZC (W)
Guest
Posts: n/a
its a long shot but check your main relay. make sure its clicking when you hit the key
Old Nov 14, 2003 | 02:16 PM
4drEF's Avatar
Keyboard Humorist
Sounds familiar. Make SURE you have the wires on the distributor cap in the right place and in the right order!
Old Nov 14, 2003 | 02:23 PM
W0oT's Avatar
Banned
Default Re: mpfi swap- cranks but no start. (4drEF)
i'm pretty sure the spark plug wires are in the right order, but i'll double check that too, i'm gonna check for spark on all 4 cyls, i'm worried that the dizzy wires are mixed up or that i have my iat sensor wires going to my iacv..... i'll check my fsm, and my 91 si to see if the wires are right(colors that is) and i still can't understand y i'm getting a code 10 for iat sensor.
Old Nov 14, 2003 | 02:36 PM
W0oT's Avatar
Banned
btw are there 1 or 2 grounds at the thermostat? i'm pretty sure i only have 1, but my fsm shows 2
Old Nov 14, 2003 | 06:32 PM
W0oT's Avatar
Banned
ok i only have 1 ground so we're fine there, i guess i had the iacv blue yellow wire hooked up to one of the injectors, so i fixed that, also did the d15 injector plugs happen to be the green and brown ones i wish i could find the ones i cut off, would have made my life tonight much easier, well so anyways, it's closer to starting no more code 10, fixed that, but still won't start right up, still tried swapping dizzy plugs, and still nothing, if i crank for 20-30 seconds it will almost start, but won't run any more idea's, spark plug wires are correct 1/3/4/2 starting from about 8 o'clock if you were to look directly at the distributor from the pass side. btw is the tandom valve the black and orange wired plug, i'm gonna look in my fsm
Old Nov 14, 2003 | 06:39 PM
W0oT's Avatar
Banned
ok so the tandom valve is the orange and black/yellow wires that i thought it was, now my question is the 2 wires i added for the CYL Sensor...... do they need to be seperated from the rest of my subharness? i read in another post that it caused problems when they werent
Old Nov 14, 2003 | 11:47 PM
Redline130's Avatar
After you changed the water pump, was the motor set to TDC and everything lined up and in time. Also, does the motor have compression? I'm just trying to take some shots in the dark.
Old Nov 15, 2003 | 12:27 AM
skrappy's Avatar
i have the same problem my car wont start too
Old Nov 15, 2003 | 05:08 AM
W0oT's Avatar
Banned
i'm 99% positive everything is lined up, it sucks because i'm sure if there not aligned correctly it's only off by a hair, wish honda made it so you could lock the crank and cams in TDC, atleast w/ b16 you could put a dowl pin in a cam tower and keep that at tdc. as for compression.... i don't know, don't have a compression tester, i'm gonna check for spark today that's the only thing i haven't done.... and i'm gonna redo my harness unfortunately that means i have to pull it off the motor and pretty much out of the car
I'll check the fuses and spark first though.
Modified by Nismo240sx1 at 2:13 PM 11/15/2003
Old Nov 15, 2003 | 08:00 AM
SOHCEK-Turbo's Avatar
Check all your fuses.
Old Nov 15, 2003 | 12:46 PM
W0oT's Avatar
Banned
Default Re: mpfi swap- cranks but no start. (SOHCV-TechRider)
fuses checked, no probs there. i'm gonna redo most of my solder connections, make the harness a little nicer..... other than that i have no clue what the prob is but maybe i made a mistake at the ecu????.....
also the only thing i can think it would be is the cyl wires are un shielded.
Modified by Nismo240sx1 at 5:16 PM 11/15/2003
Old Nov 15, 2003 | 03:47 PM
type Gendy's Avatar
Have you reset the ecu at all?
Old Nov 15, 2003 | 03:51 PM
W0oT's Avatar
Banned
yup< done that
Old Nov 15, 2003 | 05:48 PM
b18befhatch's Avatar
sounds to me like your plug wires are wrong. on the cap the got 1243 counter clockwise starting at 8 oclock and the cylinders are 1234 starting at timing belt going to the dizzy
Old Nov 15, 2003 | 07:28 PM
Redline130's Avatar
Default Re: (dippincrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dippincrx &raquo;</TD></TR><TR><TD CLASS="quote">sounds to me like your plug wires are wrong. on the cap the got 1243 counter clockwise starting at 8 oclock and the cylinders are 1234 starting at timing belt going to the dizzy </TD></TR></TABLE>
He's already confirmed that he has the plug wires correct.
Nismo~have you checked for spark yet?
W0oT's Avatar
Banned
i thought it was 1342
duh nevermind 1342 is clockwise, 1243 is counter your right allready tried that.
Modified by Nismo240sx1 at 6:56 PM 11/16/2003
