Need Help w/ Type R sway Bar install!!!???!?!!
Old Nov 13, 2003 | 04:41 PM
4DooRGiSzer's Avatar
Default Need Help w/ Type R sway Bar install!!!???!?!!
hey, i tried to put in the sway bar today, i have new endlinks, and the new pieces you see below, but when i went to bolt these on, they didnt match up to the stock wholes! what else do i need to get to make these fit on?? please help, i need to take that pencil for a sway bar off. thanks in advance for any and all help!
-dusty
this is what does not match up to the stock holes, the distance between the bolt holes is tooo big.
Old Nov 13, 2003 | 04:45 PM
IntEGNYC's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (4DooRGiSzer)
*hint* *hint*
search for the BSQ kit.
Ive had the ITR rear sway on mine for two years. :D
Old Nov 13, 2003 | 04:47 PM
tornactive.com's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">*hint* *hint*
just in case:
https://honda-tech.com/zerothread?id=663795
thanks i will look it up
Old Nov 13, 2003 | 05:54 PM
BSQ's Avatar
BSQ
Here is a direct link to my webpage which contains step-by-step instructions for installing the Type-R rear swaybar: http://www.geocities.com/bretq....html
Also, go to http://www.geocities.com/bretq/mounting_kit.html for my BSQ Type-R rear swaybar mounting/reinforcement kit (aka. BSQ kit).
Old Nov 13, 2003 | 05:58 PM
skunkintegra's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (BSQ)
BSQ kit still gets from me!!
installed for over 6 months!!... very intensive driving... and ZERO subframe tearout!!
for the DIY's Bret!!
Old Nov 15, 2003 | 09:49 PM
andlude's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (skunkintegra)
sorry about this, but this is 4DoorGiSzeR, not andlude talking....
so i must be an idiot, but i got the Beaks kit now, and i still cant figure out how to make it all mount up. i read the directions on the link above on how to do it all. but i just dont get how to make it work.
Old Nov 15, 2003 | 09:57 PM
P1mpSlap's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (tornactive.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tornactive.com &raquo;</TD></TR><TR><TD CLASS="quote">
just in case:
lol shamless plug
Old Nov 17, 2003 | 01:25 PM
blk95_gsr's Avatar
Just called King motorsports got the rubber inserts.(20.00) swapped the stock GSR mounts around and installed. Bolted right up have had in for 5 months of hard driving. (stock height) No complaints.
Old Nov 17, 2003 | 01:55 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (blk95_gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk95_gsr &raquo;</TD></TR><TR><TD CLASS="quote">Just called King motorsports got the rubber inserts.(20.00) swapped the stock GSR mounts around and installed. Bolted right up have had in for 5 months of hard driving. (stock height) No complaints.
stock GS-R swaybar mounts w/ ITR bar is a no-no, that is exactly what will make the bar tear out of the chassis, the fact that those bar mount brackets put the bar farther away from the chassis, therefore exerting more torque on the subframe.
Old Nov 17, 2003 | 04:47 PM
Teknic73's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (PatrickGSR94)
go here and look what happened to my friends car https://honda-tech.com/zerothread?id=638838
get a beaks kit and save your self from misery http://www.beaksproducts.com
Old Nov 17, 2003 | 05:57 PM
silvrintegra's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (Teknic73)
http://student.ucr.edu/~ohe02/
This will help with the install, just go to the DIY page. As far as fitting get a BSQ or Beaks both will do the job. I personally got the BSQ.
Good Luck.
Old Nov 17, 2003 | 07:29 PM
thaiphob's Avatar
Nikon!!!
just wait till your sub frame tears out.
Old Nov 17, 2003 | 07:35 PM
216.226.142.95:27016's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (silvrintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvrintegra &raquo;</TD></TR><TR><TD CLASS="quote"> http://student.ucr.edu/~ohe02/
very nice writeup! i have my swaybar just sitting my living room. if anyone wants 22mm sway bar in a discount price, get one from gettle acura.
Old Nov 17, 2003 | 09:56 PM
:jdmshmaydm:'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teknic73 &raquo;</TD></TR><TR><TD CLASS="quote">go here and look what happened to my friends car https://honda-tech.com/zerothread?id=638838
get a beaks kit and save your self from misery http://www.beaksproducts.com </TD></TR></TABLE>
That's not a pretty site. BSQ's kit for me when I get this sway.
Old Nov 18, 2003 | 06:07 AM
Community Builder
did you see this on page 2 of that thread?
Old Nov 18, 2003 | 06:17 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
****!!!!!!!!!!!!111
That guy must beat his car pretty hard.
Old Nov 18, 2003 | 06:30 AM
Community Builder
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (P1mpSlap)
don't forget, the softer the springs, the more stress there will be on the subframe if a big swaybar is used.
Old Nov 18, 2003 | 07:56 AM
Scary1109's Avatar
holy sh#t, that's even got a kit on it. he must have had some really soft springs on huh?
-Scary
Old Nov 18, 2003 | 08:49 AM
Community Builder
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (Scary1109)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scary1109 &raquo;</TD></TR><TR><TD CLASS="quote">holy sh#t, that's even got a kit on it. he must have had some really soft springs on huh?
-Scary</TD></TR></TABLE>
He was running Tein HA's which have 335 lb/in springs in back. He had run the car in quite a few track events before that happened.
Old Nov 18, 2003 | 10:51 AM
WalkmanX's Avatar
daymn and I was just gonna get my ITR sway bar today too
I think I'll still get it with the BSQ kit but have you guys ever tried the SRR Lower Tie bar?
Should I also get the stock ITR bracket/bushings or an aftermarket ES one from autozone?
Old Nov 18, 2003 | 07:08 PM
darrinbrewer's Avatar
Default Re: Need Help w/ Type R sway Bar install!!!???!?!! (WalkmanX)
i've got a 4dr 94 gsr with R springs/gsr stock shocks in the rear...i should be OK with a bsq or beaks kit..right?
Old Nov 19, 2003 | 12:26 AM
Mr. Choi's Avatar
New User
He was running Tein HA's which have 335 lb/in springs in back. He had run the car in quite a few track events before that happened.</TD></TR></TABLE>
wow.
my friend has no problem using the same suspension a bsq mounting kit, not beats.
Old Nov 19, 2003 | 08:12 AM
ebelp's Avatar
Owned!!
hamburgler
15
Feb 20, 2007 04:42 AM
kame1997
Suspension & Brakes
16
Mar 29, 2006 12:43 PM
AlxSiR7
Dec 11, 2004 02:26 PM
DeSolMan007
Apr 7, 2003 08:22 PM
dgdarien
10
Mar 30, 2003 01:09 PM
