What dizzy do i need?!?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 »</TD></TR><TR><TD CLASS="quote">uhmmm not you need an 88-89 integra...</TD></TR></TABLE>
Not for a SOHC ZC. The SOHC ZC is basically the same as an A6.
well i went to put on the new dizzy the other day, and it won't seem to fit no matter what i do. the distributer is off of a 91 crx si...
it will fit though, right? maybe i just need to mess around with it a little bit more.
while on the topic, how do i adjust the number 1 piston to TDC? the chilton manual says to set the first piston to top dead center...i'm assuming for timing issues so my car wont run like pooooooop? thanks guys...
-cody
-cody
It won't fit? why?
Make sure you have the two keying features on the distributor lined up with the pockets in the cam correctly. The only go in one way so don't force them in there. If they don't slide in, spin the distributor 180 degrees and try it again.
02 coupe
Jun 5, 2005 04:57 AM
