tranny pops out of gear.
Old Nov 13, 2003 | 12:05 PM
Evil EG's Avatar
Default tranny pops out of gear.
Well I installed a clutch and at the same time we put in a lsd but ended not installing it but we had the case apart. So now its been in the car about 3 weeks and now 4th gear is popong out of gear when ever you get on the gas. Does the spring and ball bearing that goes in the beseries trans have any thing to do with that... Cause we bent the spring up pretty bad when we put the case back on(forgot it was still in the case ) What else would casue it...
Old Nov 13, 2003 | 04:24 PM
RCautoworks's Avatar
Default Re: tranny pops out of gear. (BVM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM &raquo;</TD></TR><TR><TD CLASS="quote">What else would casue it...</TD></TR></TABLE>
Bad synchros, shift linkage not adjusted right or the right lenght.
Old Nov 13, 2003 | 06:03 PM
Evil EG's Avatar
Default Re: tranny pops out of gear. (90blackcrx)
motor and trans are stock. no swap.
Old Nov 13, 2003 | 06:26 PM
Does your trans grind while shifting at all ? If your shift linkage is ok, your synchros are shot.
Old Nov 13, 2003 | 06:43 PM
Evil EG's Avatar
nope no grinding goes into gear perfect. Just when you excelerate it pops its self out. Im gunna check the tranny fluid and make sure I didnt bend the shift rod when I put the bitch pin back in.
Mmmeecho
10
Jul 28, 2008 09:06 PM
sharik
11
Jun 29, 2007 11:26 PM
USDM-EK4*
Jun 5, 2007 09:33 PM
.paul
Jan 12, 2007 12:35 PM
gsrteg93
Apr 30, 2003 11:07 AM
