PLEASE POST ALL YOUR NEAR STOCK TYPE R 60' & 1/4 MILE TIME TIPS. THANK YOU!
Old Sep 10, 2001 | 03:31 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default PLEASE POST ALL YOUR NEAR STOCK TYPE R 60' & 1/4 MILE TIME TIPS. THANK YOU!
I need all the help I can get. And yes auto xing is in my near future. Thank you again.
Old Sep 10, 2001 | 03:34 PM
Willard's Avatar
Default Re: PLEASE POST ALL YOUR NEAR STOCK TYPE R 60' & 1/4 MILE TIME TIPS. THANK YOU! (01PYTypeR#1140)
0.528
2.365
"9.533 @ 76.83"
"14.599 @ 97.24"
Air box baffle removed.
2765 lbs. (with driver)
Willie
Old Sep 10, 2001 | 03:36 PM
Toda Party's Avatar
Default Re: PLEASE POST ALL YOUR NEAR STOCK TYPE R 60' & 1/4 MILE TIME TIPS. THANK YOU! (Willard)
stock (no spare, no jack, lower front tire pressure)
60 - 2.252
1/8 - 9.644 @ 75.84
1/4 - 14.890@ 92.73
AEM CAI ( no spare, no jack, stock tire pressure - 35F/33R)
60 - 2.301
1/8 - 9.449 @ 76.70
1/4 - 14.522 @ 95.79
Old Sep 10, 2001 | 03:55 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
60'.....2.371
330....6.282
1/8....9.555
1/4mi...14.792@93.17mph
Air temp was over 80 degrees and humidity was over 90%.
Avoid the water box on street tires. Before I staged I did an e-brake burn to heat the tires (rev to 7k and drop clutch). I was holding my revs between 5-5.5k. I launch by slipping the clutch a little at first then coming off it almost all the way but not quite. The whole slipping process was fairly quick as not to burn the clutch. Just make sure you don't spin it right off the line. Once the car is moving a little go ahead and let the tires light up. The key for me was making sure the car hooked up in VTEC. I also learned that it was much better to spin out to much than to bog the car out of VTEC. My best et came when the tires hooked up at about 7k or so. My best 60' was with the tires grabbing around 8k or so but I anticipated the shift as the tach was coming back off redline so I shifted to second too soon ( at about 8.2k which hurt my time). Try to get as many runs in as possible. Practice makes perfect. I know I still have alot to learn and I need alot more practice. This is from my personal experience which I know is not even close to perfect, but I was able to obtain somewhat respectable times. Good luck.
Old Sep 10, 2001 | 05:01 PM
THIS IS GREAT STUFF! PLEASE KEEP IT COMING. THAT WAY WHEN SOMEONE DOES A SERCH ITS ALL RIGHT HERE.
Old Sep 11, 2001 | 08:34 PM
ttt
Old Sep 11, 2001 | 10:21 PM
RagingAngel's Avatar
2615lbs, no spare, toolkit etc. but full interior....
stock motor.....
60ft. 2.202
WAit...crap.it's all in my sig.....
[Modified by RagingAngel, 11:21 PM 9/11/2001]
Old Sep 12, 2001 | 06:52 PM
Default Re: PLEASE POST ALL YOUR NEAR STOCK TYPE R 60' & 1/4 MILE TIME TIPS. THANK YOU! (RagingAngel)
ttt
Old Sep 13, 2001 | 06:13 AM
Ideal R's Avatar
New User
with gtech controller, i got high trap speed (95mph) but crappy 1/4 miles time (mid 15's)
is it the gtech not accurate, or my start up is too crappy?
thx in advance
Greg50Lt
Honda Civic (2006 - 2015)
Sep 9, 2007 06:16 PM
el arbi
Apr 4, 2003 12:48 PM
JDMTypeS
Apr 10, 2002 12:48 PM
S2KILLA
Mar 31, 2002 02:01 PM
ActiveAero
Sep 7, 2001 09:50 PM
