How to change/flush coolant? Online instructions?
Old Nov 13, 2003 | 09:59 AM
TypeRuz's Avatar
Default Where to get ON-LINE instruc. to change/flush coolant???
i'm planning on flushing and changing my own coolant this weekend since it's looking kinda dirty.
i've never done it before, and unfortunately, i don't have a helm's manual...yet.
so, does anyone know any good websites with pics to give me step-by-step instructions??
i know there is the drain plug on the bottom, but i heard there are a few other drains to release any air that may get into the system.
thanks!!
Old Nov 13, 2003 | 10:05 AM
B2FiNiTY's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (TypeRuz)
Only 2 things you need to worry about.
Plug on the bottom and bolt on the block. That is it.
The bolt on the block is for the block and the plug on the bottom is for the radiator.
To bleed the radiator, start up the car with the cap off and watch the bubbles appear. Once they stop coming up, you have bled your system.
Old Nov 13, 2003 | 10:08 AM
stRtypR25's Avatar
when flushing the system do not forget to take out the thermostat
TypeRuz's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (B2FiNiTY)
do i first let the coolant drain from the radiator and block, and then start?
btw, where is the plug on the block?
Old Nov 13, 2003 | 10:20 AM
B2FiNiTY's Avatar
You don't need to remove the thermostat.
The plug on the block is on the bottom end. Your header is covering the view of it. Take off the heatshield if you want to see it more clearly.
Old Nov 13, 2003 | 10:21 AM
B2FiNiTY's Avatar
Here you go:
1) Drain the radiator
2) Drain the block
3) Plug the block back up
4) Plug the radiator back up
5) Fill the radiator
6) Start up the car to bleed it
Old Nov 13, 2003 | 10:24 AM
Chris N's Avatar
I think you need to buy a Helms.
It's all in there, and it is definitely worth the money
Old Nov 13, 2003 | 10:52 AM
Art Vandeleigh's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (stRtypR25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRtypR25 &raquo;</TD></TR><TR><TD CLASS="quote">when flushing the system do not forget to take out the thermostat</TD></TR></TABLE>
what are you talking about?? why heck would you want to make an easy job into a PITA job?
Old Nov 13, 2003 | 11:50 AM
vtec.dc2's Avatar
can you explain the need to remove thermostat?
Old Nov 13, 2003 | 12:33 PM
nightrider's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
can you explain the need to remove thermostat?</TD></TR></TABLE>
seriously, i'll be worried if i had to remove the thermostat because i stripped the bolt. anyone know how to get the nut loose if it's stripped?
Old Nov 13, 2003 | 12:58 PM
Tweakmeister's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (nightrider)
Another vote here to buy the damn Helms already...it'll tell you things like Torque specs too...
Block bolt is right there:
Old Nov 13, 2003 | 03:37 PM
95TEG's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (Tweakmeister)
http://www.team-integra.net/se...D=421
Old Nov 24, 2003 | 06:05 PM
integraL's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (95TEG)
how do you know how much torque you're putting on the bolt?
Old Nov 24, 2003 | 06:10 PM
Chris N's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (integraL)
You buy (and use) a torque wrench.?
Old Dec 5, 2003 | 04:37 PM
Lang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TEG &raquo;</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=421</TD></TR></TABLE>
great link! step by step w/pix. you've gotta register to access this page though.
Old Dec 5, 2003 | 04:43 PM
Mr. TopFuel's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (Lang)
i never heard of the helms book..were u get one?
Old Dec 5, 2003 | 05:00 PM
jonas's Avatar
http://www.helminc.com
Old Dec 5, 2003 | 05:01 PM
B2FiNiTY's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (TypeRxMugen)
helms basically = honda/acura factory book.
Old Dec 5, 2003 | 06:03 PM
jdmspoonitr's Avatar
dc2 is out of stock....at least a couple weeks ago they were.
Old Dec 5, 2003 | 09:03 PM
uNF$@#!'s Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (jdmspoonitr)
one other thing...coolant BURNS....
if you ever want to know how chemical burn feels like, take a shower in this stuff
Old Dec 5, 2003 | 09:10 PM
Smitdog's Avatar
Default Re: Where to get ON-LINE instruc. to change/flush coolant??? (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">one other thing...coolant BURNS....
if you ever want to know how chemical burn feels like, take a shower in this stuff </TD></TR></TABLE>
SO true...
- Learned the hard way once back in the day.....
Old Dec 5, 2003 | 09:15 PM
Asahi's Avatar
http://www.bseries.net/html/garage/thermo.php
Jeff Lebowski
Nov 14, 2016 05:02 PM
atikovi
Oct 7, 2010 05:49 PM
xiaogou
Sep 15, 2006 07:09 PM
sinister357
Apr 29, 2005 05:20 PM
You_Get_Vapors
Jun 16, 2003 09:17 PM
