where do i go from here....
Old Nov 13, 2003 | 07:43 AM
ek four's Avatar
Default where do i go from here....
Modified by ek four at 1:05 PM 6/9/2005
Old Nov 13, 2003 | 07:57 AM
-iLLuZioN-B18C1's Avatar
Default Re: where do i go from here.... (ek four)
off the top of my head
swap to higher compression pistons(civic r), cams(jun3's are nice)
p&p, type r head can be improved, so go ahead and upgrade valvetrain.
intake mani, throttle body...suspension is good too. work on that as well if you havnt done so already.
Old Nov 13, 2003 | 09:15 AM
lke2drvgsr's Avatar
Default Re: where do i go from here.... (-iLLuZioN-B18C1)
headertech or smsp or hytech header... easy hp right there
Old Nov 13, 2003 | 09:21 AM
lke2drvgsr's Avatar
up to 20 whp on the smsp or hytech, around 10-15 on the headertech... smsp are 1300 for a set tho, headertech's are like 700..
Old Nov 13, 2003 | 11:34 AM
98itR484's Avatar
Default Re: where do i go from here.... (lke2drvgsr)
wasssssssssuppppppppppppppp
Long time no see....
I would say go with the SMSP header, yea there is a significant wait, but let me tell youl, its more than worth it, i gaine 23WHP with just the SMS header, yea, 23whp. Ask around the peeps at autolink they were there for the before/after dyno. I'd also look into some cams....CHECK PM
Old Nov 13, 2003 | 01:20 PM
Revhard92si's Avatar
Get all the basic bolt-ons first. Send the head in to get it port and polish. While the head is sent in, have the shop upgrade the whole valvetrain (springs, retainers, valves). If you're going to be using Jun 3 cams you'll need the upgrade springs. After that if you still haven't reach you goal, send you block in and have it bore to 84mm and add some high compression pistons.
Old Nov 14, 2003 | 12:56 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">smsp are 1300 for a set tho, headertech's are like 700..</TD></TR></TABLE>
yeah , just like that but the opposite.
Old Nov 14, 2003 | 02:20 PM
lke2drvgsr's Avatar
Default Re: where do i go from here.... (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
yeah , just like that but the opposite.</TD></TR></TABLE>
umm... lol... you can get a set of headertech for 500, and ive seen smsp at minimum for 1k... where the hell do u get the idea that those prices are opposite???
Wilka
51
Feb 5, 2016 03:41 PM
clem kevin
Feb 5, 2007 08:04 AM
djmota
11
Jun 30, 2004 11:36 AM
AussieK24
Jun 29, 2003 05:19 AM
Civic89
Jul 9, 2002 07:35 PM
