1st gen B16a, will GSR tranny fit?
Do all B-series motors bolt up with B series trannys? Cause i am thinking about buying a GST transmission, but i want to be sure that it will fit my B16a motor, will there be any problem with this, or should it bolt right up. And i dont want to hear any posts about how i will lose acceleration from the longer GSR gearing, i already know that my S1 is geared much shorter, and that is part of the reason why i want a GSR trans, cause i do alot of highway driving.
Thanks
Tyler
Thanks
Tyler
yeah all B-series will fit. I had a friend put a GSR tranny on a B16 in his integra. Yeah I know what your thinking "B16 in a integra???" It was his temp motor until he got his ITR before he got scammed
Since you have a B16 you should consider saving up for a S80 Tranny and getting the hasport cable-tranny conversion. Just a thought
Thanks alot for the info man, as far as your suggestion, i am on a somewhat limited budget, so probably a no go for any fancy trans, just need one that doesnt run really rough and grind third
. Thanks for letting me know that the Btranses are swapable tho
Tyler
. Thanks for letting me know that the Btranses are swapable thoTyler
Is this for that CRX in your sig?
You will need a cable version to work in your CRX. The hydro GSR transmissions 94-2001 would need to have hydro-cable conversion to work.
Hell it does not matter what year GSR trans....they are getting harder to find at a good price everyday.
Good luck
Good luck
All B series trannys from the 90-01 Integra's, 99-00 Civic Si and 93-97 Del Sol VTEC and of course the JDM trannys will bolt up. There is an exception which is the older 88-91 B20 Prelude's which aren't interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gatesrex91 »</TD></TR><TR><TD CLASS="quote">Thanks alot for the info man, as far as your suggestion, i am on a somewhat limited budget, so probably a no go for any fancy trans, just need one that doesnt run really rough and grind third
Tyler</TD></TR></TABLE>
hey man if your having problems with grinding in 3rd you may want to consider replacing your tranny fluid with GM synchromesh friction modified and see how it reacts
. Thanks for letting me know that the Btranses are swapable thoTyler</TD></TR></TABLE>
If you look around carefully, you may be able to a 92-93 gsr tranny which is known as the YS1 which shares almost the same ratios as the late type R gearboxes, except no lsd. This tranny is cable and bolts right up with no need for a cable to hydrolic conversion. I found one a couple years ago from a salvage yard out in the middle of nowhere that had been sitting around for years. It had only 9000km's original on it, and set me back $850 Canadian.
One other thing, make sure if you get a ys1, its from a 92-93 gsr only. The ls,rs,gs models had a ys1 also, but much more relaxed gearing.
Deetz
Deetz
VTEC2841
May 9, 2007 04:12 PM
FunIntegras
Jun 29, 2004 10:43 PM
