A little help from you civic guys
Old Sep 10, 2001 | 01:58 PM
cjohnson_2's Avatar
Default A little help from you civic guys
My GF has a problem with her 1991 Civic Dx. When its on the battery light will come on. but it will go awy as soon as she starts to drive it. We changed the battery on it but that didnt help. any of you have any suggestions?
Old Sep 10, 2001 | 02:25 PM
fixhondas's Avatar
Default Re: A little help from you civic guys (cjohnson_2)
sounds like a weak alternator- save yourself some time and aggrivation when you replace it by getting a Honda alternator. So you rev it and the light goes out? One thing you might try when it is idling- smack the alternator with a long screwdriver or prybar- sometimes the brushes hang up.
Old Sep 10, 2001 | 02:32 PM
maxim's Avatar
Default Re: A little help from you civic guys (fixhondas)
check to see if her lights dim when the car is on...might be the alternator.
Old Sep 10, 2001 | 02:34 PM
CiViC TyPe X's Avatar
New User
i had that problem on my 1991 240sx
the mechanic suggested that i hit it with a hammer just to get me home
than i immediately changed it
Old Sep 10, 2001 | 03:31 PM
cjohnson_2's Avatar
Default Re: A little help from you civic guys (CiViC TyPe X)
I went to a Trak auto and had them test the alternator. they said it was charging the battery normally.. any other ideas?
[Modified by cjohnson_2, 6:32 PM 9/10/2001]
Old Sep 10, 2001 | 04:19 PM
fixhondas's Avatar
the only thing that lights the battery light is the voltage regulator in the alternator. If you were in columbus you could bring to my work and I could test it for you. But you're not so I can't. You will most likely need an alternator. If you unplug the connector on the back of the alternator and the light goes out with the key on - you need an alternator.
[Modified by fixhondas, 1:20 AM 9/11/2001]
meterus
Feb 10, 2011 03:00 AM
88 EF Hatch
Sep 17, 2009 07:29 AM
vietkangta
Oct 21, 2007 09:20 PM
JCritt
Jun 24, 2004 07:28 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
