throttle cable?
Old Nov 13, 2003 | 02:48 AM
90hbvtec's Avatar
Default throttle cable?
ok guys with ur new b16 motor.. i have a 90 si hb civic can i use my stock throttle cable with some mods or co i have to replace them with some toher throttle cable..let me know thanks
Old Nov 13, 2003 | 04:23 AM
Home Skillet's Avatar
Default Re: throttle cable? (90hbvtec)
You'll be fine with the stock throttle cable.
Old Nov 13, 2003 | 04:33 AM
HatchBox's Avatar
Skoobie no more...
hpcracing makes a bracket :thumbsup:
10bucks be there in 2 days
Old Nov 13, 2003 | 06:28 AM
RCautoworks's Avatar
Default Re: throttle cable? (ind3ciso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">hpcracing makes a bracket :thumbsup:
Yes they do, but make sure the bracket will work for you before buying it. The bracket moves the mounting point over to the tb more, which in some cases you actually have to move it the other way a little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">You'll be fine with the stock throttle cable. </TD></TR></TABLE>
Some people don't have problems with it, some do, so that not 100% true.
Old Nov 13, 2003 | 06:35 AM
Default Re: throttle cable? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Some people don't have problems with it, some do, so that not 100% true.</TD></TR></TABLE>
That's news to me. In what instances are the cables not long enough? Are the 88-89's different from the 90-91's? I dunno.
Old Nov 13, 2003 | 06:54 AM
Default Re: throttle cable? (Home Skillet)
I have ran into this problem with few 90-91's, some needed to be moved towards the driver side fender and some needed to be moved the other way. Maybe the cars were in accidents before.
Old Nov 13, 2003 | 10:34 AM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90hbvtec &raquo;</TD></TR><TR><TD CLASS="quote">ok guys with ur new b16 motor.. i have a 90 si hb civic can i use my stock throttle cable with some mods or co i have to replace them with some toher throttle cable..let me know thanks</TD></TR></TABLE>
I used a 90 Teg cable and bracket. Works great! From what I can recall the HF and the Si cable were the same length, and at first I had a homemade bracket to hold the HF cable and it was just too cheesy.
Old Nov 13, 2003 | 12:44 PM
Rywire's Avatar
Default Re: throttle cable? (Ox5647)
Yeah, deffinately invest the 15-20 bux on a teg cable. Ryan
Old Nov 13, 2003 | 12:51 PM
HatchBox's Avatar
Skoobie no more...
http://www.hcpengineering.com/bg2.html
under swap accessory's.
Old Nov 13, 2003 | 02:47 PM
CRXDRAG's Avatar
Place Racing also makes one that works very well. You can even make your own its not that hard, we made one for a 95 coupe. Good luck
vxturbociv
Apr 28, 2008 02:55 PM
Ryan562
11
Jan 14, 2007 11:56 PM
CRXified
Apr 30, 2005 01:19 PM
CNSK
Aug 4, 2004 06:29 AM
RAWB
Jun 23, 2003 12:59 PM
