car died with jumper wire
Old Nov 12, 2003 | 10:44 PM
importfan's Avatar
Default car died with jumper wire
I Made a post a while back but no one could help me, so here it is again. I have a h22 civic that ran fine for 4 days. the cel came on like normal after crusing (egr, because it's not connected) so I tested to make sure since the swap was still fresh. The car puttered to a stop when the jumper wire was put in. Has this ever happened to anyone out there? My car has everything, fuel and spark at the cyl. and 230 compression. Tested and replaced every possible part including another good engine harness, disstributor, resistor pack, 2 ecu's, injectors, underhood fuse box, and 2 main relays. The only funny thing is the spark seems weak and the motor puttered for a few secs the first couple of mournings. Any help would be welcome.
Old Nov 12, 2003 | 10:59 PM
TeStUdO's Avatar
Ignitor maybe????????/
Old Nov 13, 2003 | 05:27 AM
Jimmy's Avatar
Global Moderator
Default Re: (TeStUdO)
I would check your coil or ignitor in the dizzy.
Old Nov 13, 2003 | 03:33 PM
jdm94h22acivic's Avatar
TTT
Old Nov 14, 2003 | 07:28 AM
Default Re: (jdm94h22acivic)
TTT
Old Nov 14, 2003 | 10:23 AM
onePOINTsix's Avatar
Stop TTTing, check your igniter!
Old Nov 15, 2003 | 01:07 AM
Its not the ignitor if you would read the post! Ive got 2 distributors both are working fine.
oeldisplay
Apr 17, 2009 08:44 PM
civicdust
Feb 7, 2005 08:41 PM
jtracing919
Jan 13, 2005 06:19 AM
silver ek
Nov 28, 2004 08:11 AM
Bailhatch
Aug 5, 2004 10:13 AM
