Quick question on the oil filter bolt
Old Nov 12, 2003 | 09:43 PM
TurboTeG4's Avatar
Default Quick question on the oil filter bolt
Will a oil cooler sandwich adapter for a type r fit on a gsr b18c1?
Old Nov 12, 2003 | 10:02 PM
TurboTeG4's Avatar
Default Re: Quick question on the oil filter bolt (TurboTeG4)
the adapter bolt that is
Old Nov 12, 2003 | 10:50 PM
Spartanic's Avatar
You'll have to get the part where the oil filter threads into becuase the length will be different.
Old Nov 13, 2003 | 07:56 AM
IN VTEC's Avatar
Yes. All Honda's share the same M20x1.5 thread size and pitch.
However, you have to be careful of which plate adapters you use and for what applications. There are sandwich plate adapters and oil input adapters.
Sandwich plate adapters have to have an OUT and a way back IN to the sandwich plate adapter. If you try to use just the OUT and plug up the IN on the sandwich plate adapters, the only oil is getting back to the engine is through a tiny bypass check valve.
Oil input adapters don't need a way back in through the plate adapter. They can dump wherever you want. GE's VTEC/oil feed adapter plate is this type.
If you really do need a sandwich plate adapter, then you might run into some issues with the adapter piece being too long and not being able to put enough of any compression on the plate adapter to get the o-ring to seal. Perma-cool, Earl's, TVD (sp?), and a few others sandwich plates I have tested have this problem.
Old Nov 13, 2003 | 04:51 PM
TurboTeG4's Avatar
Default Re: Quick question on the oil filter bolt (IN VTEC)
Thanks for the info, yeah i had a oil cooler mounted on my old car and had the same problem, had to cut the thing to size. Just lost a auction on a hella nice oil cooler system from earls, too bad the auction ended 3 in the morning else i would have won it.
civicSIhatch93
Apr 26, 2013 10:42 PM
jdmdohcek98
12
Sep 27, 2011 04:06 AM
Pompiuses
Sep 3, 2010 09:29 AM
92redhatch
Jun 8, 2009 05:00 AM
Home Wrecker
Sep 20, 2006 08:54 AM
