zc help needed
Old Nov 12, 2003 | 08:05 PM
cabledog's Avatar
Default zc help needed
hey guys my zc is almost done,but i have a question..not tring to be an *** here,but if ya dont know for sure please dont reply..ok will or not..B-series rods fit into a dohc zc,using stock zc pistons.now i have heard that they will work.So please someone can you tell me this for sure..thanks ..Jay
Old Nov 12, 2003 | 08:13 PM
EP3_05's Avatar
Default Re: zc help needed (cabledog)
They will work as long as you notch the bottom of the block clear the larger rods. With the larger rods, the path in which they rotate is going to be wider than the bottom of the block.
Check out this thread for some more info on the b16a rods in a d series and the budget toyota pistons/b16a rod combo for turboed d series engines.
https://honda-tech.com/zerothread?id=207562
Old Nov 12, 2003 | 11:26 PM
cabledog's Avatar
man thanks alot...thats what i have heard but i coulnd be sure,,,the reason for this is..i got a set of 1997 gsr rods for free...so there is no need to but rods if ya dont have to..Jay
Old Nov 12, 2003 | 11:58 PM
cabledog's Avatar
oh yeah..1 more question...are the b-18 rods the same as b-16 rods..?..are the the same length as zc rods..?..later..Jay
SC-MK1
May 5, 2005 05:56 PM
mxstar777
May 7, 2004 09:35 PM
Ronin Panda
May 17, 2003 04:32 PM
Smoothy
May 6, 2003 04:39 PM
