Compression with a d16y7 block and z6 head?!
i can get a head for cheap and i have a d16y7 in my crx right now
What kind of compression and hp wil i be looking at?
i can get a hodl of some d16a1 pistons too.... but not too sure what the complete
set up will yield.... i used the online d s-eries calculator.. but couldnt figure it out
i got 12.03:1 with the y7 block and head with p29 pistons (a1)
I assume the block is the same as a y8 since its still a d16,
so bore of 75mm
Stroke of 90mm
Combustion chamber on y7 head is 34.6
3 layer head gasket
p29 pistons with 7.2 dome
piston to deck height is .040
Grand total of
12.03:1
Someone correct me if im wrong. Its bsaically the same thing as a y8 but with larger combustion chambers...actually same as the z6(cc). From what i researched.
so bore of 75mm
Stroke of 90mm
3 layer head gasket
Grand total of
12.03:1
its 10.7:1
use -2.2 the y7 dish
and the piston to deck is 0.00
I got the same setup.
Modified by BVM at 10:29 PM 11/13/2003
if there stock y7 pistons thats what the value is use the formula on the right of the calc and thats what you will come up with.
http://www.knology.net/~jediklc/D.htm
wow thats pretty good with JUST the z6 head... if i mill it, how muhc more will i gain?
what kinf or HP values are you putting down as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM »</TD></TR><TR><TD CLASS="quote">if there stock y7 pistons thats what the value is use the formula on the right of the calc and thats what you will come up with.
http://www.knology.net/~jediklc/D.htm</TD></TR></TABLE>
yeah i was using the p29 pistons not the stock ones.
Almost There
Apr 30, 2006 04:22 PM
mrmechanic
Oct 15, 2004 05:16 PM
pip9
Jul 12, 2004 05:10 PM
