help problem with 90 integra auto feeling like slipping
Old Nov 12, 2003 | 06:15 PM
eg:R's Avatar
Default help problem with 90 integra auto feeling like slipping
like topic saids, my car start slipping when i rev the motor past 2k rpm, this is an auto integra 90, and when put in gear, the gear does not engage right away anymore, something it does engage and sometime it takes a while to engage, anyone know my problems? is the tranny mess up or there is some maintance that i need to do? the fluild are at spec's or normal, thanks
Old Nov 12, 2003 | 06:36 PM
BluLude's Avatar
Default Re: help problem with 90 integra auto feeling like slipping (jacklee)
sounds like internal tranny problems, try changing the fluid to see if it helps, when you take the plug off look at the magnetic part or in the pan to see if it has some metal flakes that come out.
Old Nov 13, 2003 | 11:51 AM
eg:R's Avatar
Default Re: help problem with 90 integra auto feeling like slipping (BluLude)
i change the fluid and it is still the same, it also had very very little flakes, rearly any flakes,
Old Nov 13, 2003 | 12:27 PM
BluLude's Avatar
what did the fluid look like, the color i mean, the new fluid was like a transparent red was the old fluid you got from the transmission a dark red? I think you are gonna need a rebuild either way or get a used transmission
memphisfuk
Mar 13, 2010 07:35 AM
mynameizstitch
Apr 26, 2007 12:26 PM
1990AccordEX
Jan 8, 2006 05:57 AM
DAguyLS
Apr 23, 2005 06:28 PM
