how to make engine like new again??
Old Nov 12, 2003 | 05:56 PM
hondeducation's Avatar
Default how to make engine like new again??
hello. i have a b20z soon to be a b20z/vtec... anyway, i want this engine to perform as if it was bran new out of the factory. what are some things i should do (besides replacing EVERYTHING, for you comedians out there)?? change seals, gaskets, belts... anything else??
Old Nov 12, 2003 | 06:44 PM
Maximus's Avatar
Default Re: how to make engine like new again?? (hondeducation)
If you want to get it as new as possible; hot tank the block, bore and hone the cylinder walls, change every seal and pump, bearings, blue printed and balanced, and then finally professionally built.
http://www.importbuilders.com I went with them for my b20/vtec motor and also look in my signiture as well.
Old Nov 13, 2003 | 10:17 AM
Default Re: how to make engine like new again?? (Maximus)
wow, thanks a lot man! i'll surely look into doing the same as you!
olddohc
Nov 22, 2010 10:01 AM
84DA69
Nov 24, 2006 02:05 PM
CivicTypeR00
10
Nov 29, 2003 09:45 PM
battyx
Jan 5, 2002 04:55 PM
