what happens when you run your car without an o2 sensor and you have a94 gsr
i have a 94 gsr , and i have to see if my engine will still turn over after the crash . . . i have no o2 sensor now and no cat , so i would just run it with a header , ( not on the street , just in the car hold for a sec )
my primary o2 sensor is broken...the only difference i've noticed is that the gas mileage has dropped just a little.
Car should still run...but yeah...don't expect good gas mileage out of it. And it may stutter or hesitate...I'm not sure.
ok, yea its a 94 so no 2ndary O2 sensor , but the one i had got ripped out
and i need to see if its running .
also when my car is in gear and up in the air , one wheel spins one way and the other the other way , i dont remeber that happening before , ( i have suffered tranny damage) before that when i would have it in gear the wheel wouldnt turn at all . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">Without the 02 sensor, your car will run in "limp" mode.
4400 rev limit, no vtec, horrible gas milage, just to name a few</TD></TR></TABLE>
ok thats fine , as long as it will crank and run for a min to see if everything is kool
4tika4
Jul 25, 2009 05:23 AM
cr00klyn718
13
Apr 24, 2003 01:28 AM
