new motor mount design
ok,i have broken two bell housings,where the mount connects to the bell.i have been designing a set of mounts that will sit the axles in the car perfectly straight and have a bit of adjustability to them.i am using the hasport mounts on the sides with a angle cut plate under the bottoms to angle the head towards the front of the car and we are taking and mounting the rear mount upside down onto the bottom of the k member.from the rubber mount it has a chromoly rod with heims that go's to a plate that is mounted on the bottom of the bellousing,and another rod that angles towards the top and mounts to a plate that wraps around the edge of the bellhousing.the heims will allow a slight adjustability to throw a bit of weight forward.
ill post some pics after its all done,then off to the track for a little testing.
see ya!
brian
sangamon valley racing
see ya!
brian
Brewer
Mar 23, 2004 07:30 PM
