Assemble Bottom End to be Balanced?
Old Nov 12, 2003 | 04:20 PM
LudeyKrus's Avatar
Default Assemble Bottom End to be Balanced?
I'm about to get my bottom end balanced at a shop, and I'm wondering if I should assemble it before taking it up there? If so, what all should I assemble? Also, if so, should I take care and torque it all to spec?
Old Nov 12, 2003 | 04:40 PM
eghonda's Avatar
Default Re: Assemble Bottom End to be Balanced? (LudeyKrus)
no need to assemble it all. i'd bring the pistons, rods, crank and crank pulley. you can include the flywheel(+bolts) and clutch plate as well.
Old Nov 12, 2003 | 05:37 PM
DrakeMK3's Avatar
Definitly do not assemble it before you take it. You will just have to disassemble the block when you get there. The purpose of balancing an engine is, of course, smoother operation. They achieve this by making sure each of the different parts weigh the exact same as their same type e.g. rods all weigh the same........yada, yada, yada. You get the idea, I'm sure.
GarageAlchemist
Jun 21, 2006 01:30 PM
jdmd
Nov 26, 2003 01:27 PM
itr1236
Aug 5, 2001 09:14 PM
