Hed Stud Question. Help Please!!!
Old Nov 12, 2003 | 04:13 PM
importimage's Avatar
Default Hed Stud Question. Help Please!!!
I have a 89 Civic DX. I am wondering if you need to lube the head studs in oil before torquing them to spec!
Old Nov 12, 2003 | 06:47 PM
redcrx187's Avatar
yesyesyesyesyesyesyesyesyesyesyes or antiseize
Old Nov 12, 2003 | 07:36 PM
Limited S.L.I.P.'s Avatar
Default Re: (redcrx187)
BUMP- i dont think so.. def dont over do it.. anyone else?
Old Nov 12, 2003 | 07:45 PM
DEVIN22CBR's Avatar
Default Re: Hed Stud Question. Help Please!!! (importimage)
No..Atleast not down here in the south. But rust is prob a huge problem up there eh
Old Nov 12, 2003 | 09:33 PM
Vinceg99's Avatar
Default Re: Hed Stud Question. Help Please!!! (Sac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sac &raquo;</TD></TR><TR><TD CLASS="quote">No..Atleast not down here in the south. But rust is prob a huge problem up there eh</TD></TR></TABLE>
OK it doesnt matter if you drive through a salt storm your HEAD bolts should NOT be rusting if they are you have more problems than winter.
As for lubing them I have heard that you do use a little motor oil on them??
Old Nov 13, 2003 | 01:53 AM
Default Re: Hed Stud Question. Help Please!!! (Vinceg99)
So, do you oil them up or not? Also, what if a head stud is rusted...Is it garbage?
Old Nov 13, 2003 | 03:30 AM
racerxadam's Avatar
You are talking about the studs that hold the head to the block right? Lubing them changes the torque spec that should be used. You should check with the manufacture of the studs for the correct procedure and torque spec. If they are rusty you should hit them up with a scotch brite pad or wire wheel to take the rust off.
Old Nov 13, 2003 | 12:49 PM
Default Re: Hed Stud Question. Help Please!!! (racerxadam)
Sounds good. Thanks to all of you for your input!
projectef
Nov 7, 2008 12:15 PM
hiphop23j
Aug 10, 2008 03:14 PM
crvtkllr
Mar 29, 2007 01:00 PM
doug118
12
May 9, 2006 04:21 PM
B18EG6
Apr 24, 2003 01:48 PM
