'90-'91 CRX dash into '89?
Old Nov 12, 2003 | 03:55 PM
guttedEF's Avatar
Default '90-'91 CRX dash into '89?
Does anyone know if a '90-'91 CRX dash and door panels will fit into an '89 CRX? I'm selling mine and someone wants to know before he buys it, and I don't wanna tell him inforrectly.
Old Nov 12, 2003 | 03:57 PM
0554's Avatar
Default Re: '90-'91 CRX dash into '89? (guttedEF)
yes the dash will fit. as for the door panels. they will fit also as long as he has his seat belts in the doors also.
Old Nov 13, 2003 | 06:55 PM
guttedEF's Avatar
I'm pretty sure that '88-'89 had the seat belts on the B-pillar, I could be mistaken though. I know that the door panels will not fit on an '88, just not sure about an '89.
So as for the dash, If he changed the harness to the new dash, it'll go right in, right?
BTW, thanx for the reply. I just don't wanna sell someone somethin' they can't use.
Old Nov 13, 2003 | 07:03 PM
gomer124's Avatar
Default Re: (guttedEF)
lota work to replace the dash, and it'll never fit quite as good as it used to
Old Nov 13, 2003 | 09:57 PM
Tw1n Turb0 Z's Avatar
My 89 Si has the belts attached to the doors
Old Nov 17, 2003 | 04:14 PM
0554's Avatar
Default Re: (gomer124)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gomer124 &raquo;</TD></TR><TR><TD CLASS="quote">lota work to replace the dash, and it'll never fit quite as good as it used to
it will always go in like it is suppose to. if you do it right. i have done 3 crx dash conversions into a civic. and they look perfect.
Old Nov 17, 2003 | 04:51 PM
Eggman's Avatar
Yes, the door panels from a 89-91 CRX are all interchangeable. It's just the 88 CRX that isn't. In fact I think you can use 90-91 Civic HB door panels too.
Yes, the dash from a 90-91 CRX will fit in a 88-89 CRX too. In fact you don't even need to change the whole dash. Just swap the cluster, cluster cover, hazard switch, dimmer switch, defroster switch, and upper steering column cover. Done.
Old Aug 28, 2004 | 04:48 PM
Custom Rex's Avatar
Default Re: '90-'91 CRX dash into '89? (Eggman)
do u need the inter guts of the crx dash? like the Venting and braces?
or will the stock civic meet up with the crx dash's center and side vents??
cjonescrx
14
Jan 8, 2010 02:06 PM
dracocrx
Jan 28, 2009 07:30 PM
Friedenreich686
Jul 9, 2005 03:27 PM
Hayasa15
Feb 9, 2002 07:20 PM
civicracer125
Aug 12, 2001 12:10 PM
