bright lights/car dies
Old Nov 12, 2003 | 08:04 AM
grntrex's Avatar
Default bright lights/car dies
my friend has a 89civic cx hatch. he was on his way to work today and when he hit his bright lights his car would die,when he stopped the car and turn off the lights the car started right up with no problems,he would then turn on lights and turn on brights again and the car would die so as long as he didn't hit the brights it was running fine.could this be a relay or a fuse maybe? any info would help thanks
Old Nov 12, 2003 | 08:53 AM
Alan Wil's Avatar
Default Re: bright lights/car dies (grntrex)
Have<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grntrex &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a 89civic cx hatch. he was on his way to work today and when he hit his bright lights his car would die,when he stopped the car and turn off the lights the car started right up with no problems,he would then turn on lights and turn on brights again and the car would die so as long as he didn't hit the brights it was running fine.could this be a relay or a fuse maybe? any info would help thanks </TD></TR></TABLE>
Have the battery and charging system checked first.
Old Nov 12, 2003 | 09:53 AM
manson's Avatar
Default Re: bright lights/car dies (Alan Wil)
BRIGHT LIGHTS...BRIGHT LIGHTS...
Old Nov 12, 2003 | 11:37 AM
IntegraXSi's Avatar
I bet the Alt. is going bad and not giveing the Batt. a good charge
Old Nov 12, 2003 | 11:44 AM
CdTriX's Avatar
yeah check the belt.
damn my dad tighten the alternator belt too tight and every time i revved the engine the lights got brighter when i downshifted it overloaded the alternator and blew =*(
Old Nov 12, 2003 | 11:49 AM
tsjeff's Avatar
Default Re: (CdTriX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CdTriX &raquo;</TD></TR><TR><TD CLASS="quote">yeah check the belt.
damn, hope that doesn't happen to me.
try checking the belt and replacing the alternator.
Old Nov 12, 2003 | 03:16 PM
Alan Wil's Avatar
Sounds like your alternator /vlotage regulator was on its way out causing it to "blow". Having the belt too tight would not cause the alternator to "blow", unless the bearings were GROSSLY worn causing the armature to contact the windings.
PS: For the original poster : GO GET YOUR CHARGING SYSTEM CHECKED before it frys something like the ECU
Whatever you do don’t “check” the alternator by “pulling” off one of the battery cables while the car is running! I had one “customer” who did so; The ECU got marginally fried by the voltage spike. The car after that had all kinds of weird running problems.
Old Nov 12, 2003 | 03:17 PM
Alan Wil's Avatar
Default Re: (IntegraXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi &raquo;</TD></TR><TR><TD CLASS="quote">I bet the Alt. is going bad and not giveing the Batt. a good charge </TD></TR></TABLE>
Or the battery is BAD /has a weak, or SHORTED cell.
The guy needs to having the charging system checked ASAP. Charging system checks are FREE at AutoZone and such so why not run it down there?
Modified by Alan Wil at 11:14 PM 11/13/2003
1sthonda
Lighting
Oct 2, 2010 09:07 AM
asianalbutt
Feb 20, 2007 12:34 PM
Amuse9
Feb 15, 2007 01:00 PM
ewing86
Sep 30, 2004 05:49 PM
al3e
Audio / Security / Video
14
Jun 1, 2003 07:17 PM
