WTF is wrong with my car? (alingment/ pulling)
Old Nov 12, 2003 | 06:26 AM
glagola1's Avatar
Default WTF is wrong with my car? (alingment/ pulling)
Ok, so my car has been pulling to the right when I accelerate and it has been getting worse. After Sunday's auto-x is horrible. I can change lanes without even having to turn the wheel.
It drives straight while coasting and breaking. I've checked the bushings in the front lower control arms and they look fine. Could my coilovers be adjusted wrong? I've never had my car corner balanced. Why would it get worse after the auto-x?
Oh, I just had my car aligned last week for what that's worth. It did this before the alignment too but it has only gotten way worse after the auto-x.
thanks for the ideas. That's all I'm looking for here. What should I examine next?...
Old Nov 12, 2003 | 06:36 AM
cstem's Avatar
Default Re: WTF is wrong with my car? (glagola1)
Take a visual check of the ball joints, tie rod ends etc. to make sure nothing is loose or pulling out of socket. The alignment shop should have caught this on your visit there. It sound to me like a ball joint or tie rod problem. Maybe a crushed stock bushing in the arms. The torque from autocrossing (acceleration creates torque steer to the right on most cars) may have pulled or damaged furhter the rubber items in the suspension and steering.
Old Nov 12, 2003 | 08:59 AM
EG-lowrider's Avatar
if you auto-x then Im sure your tire pressures are all the good and balanced, if not do so. If there are no messed up or broken suspension parts, then it is an alignment issue, probably your thrust angle, the part of an alignment that sets you car straight, like when cars dog track (go down the road crooked like a dog) or mabey even a toe issue, probably not camber though, because you can see a camber problem by looking at the wheel from the front of the car, ie, is one front wheel sloped more than the other?
Old Nov 12, 2003 | 09:43 AM
glagola1's Avatar
Default Re: (Broke@$$tuner)
I have adjustable camber with a kit that uses non-centric hinges on the upper control arm. I know that after the alignment I had -1.5 on the driver side and -1.8 on the passenger side. It pulled under acceleration slightly and was somewhat annoying. Now it's not slight and is very annoying. Is it possible that my camber came out of whack and that's what's causing the pull?
Old Nov 12, 2003 | 10:40 AM
migs's Avatar
Default Re: (glagola1)
It is possible that your camber is out of spec, again, but the likelihood of that happening is small.
Rotate your tires front to back. Drive it then, it shouldnt pull. If it does not pull, you have a bad tire. The bad tire is on the front of the side in which the car is pulling. Tires also do cause a pulling effect (defective tire).
Check your axles. I just changed out an axle for a fellow HT member with the EXACT same symptoms, it ONLY pulls under acceleration, it also had a vibration as well.
Old Nov 13, 2003 | 03:45 PM
deffidently recheck the camber then, its very possible it could have vibrated or jared itself loose
Old Nov 13, 2003 | 10:12 PM
92BlackSi's Avatar
If not suspension then pressure or shifted/broken belt in tire possibly. Could also be the maDD TQ all us Honda owners output
Old Nov 14, 2003 | 04:52 AM
glagola1's Avatar
Default Re: (92BlackSi)
Hey 92BlackSi, I used to push 259 lb-ft of torque through this drive train so... don't laugh.
Old Nov 14, 2003 | 05:51 AM
92BlackSi's Avatar
Glagola1 - obviously I am joking and obviously there are Hondas that output tonnes of power.
Old Nov 14, 2003 | 06:09 AM
glagola1's Avatar
Oh don't get me wrong my car makes pitiful torque now. (b16 as oppposed to the boosted LS I used to run)
It's all good and thanks for the replys.
Nicefeet
Sep 24, 2011 04:31 PM
civicdelsol33
Jan 17, 2011 11:01 AM
TravisCadello
Dec 20, 2008 02:25 PM
ilu
Feb 8, 2006 12:43 PM
essex
10
May 23, 2005 09:41 AM
