turbo LS or turbo vtec?
Old Sep 10, 2001 | 08:34 AM
supergodzilla's Avatar
Default turbo LS or turbo vtec?
I thought about getting a civic HB or an integra and doing a turbo. My question is which is better for boost applications? A LS motor or the B18C?
Thanks
Old Sep 10, 2001 | 09:00 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: turbo LS or turbo vtec? (99prelude)
get a hatchback, put the gsr motor in it, bolt the drag kit, rip some @$$ like never before . "i my turbo hybrid hatch."
Old Sep 10, 2001 | 09:24 AM
FAST94GSR's Avatar
New User
Default Re: turbo LS or turbo vtec? (ho focker)
b18c is the way to go.
Old Sep 10, 2001 | 11:03 AM
IgniteTeg's Avatar
Default Re: turbo LS or turbo vtec? (FAST94GSR)
I"m kinda confuse here but here goes, are you guyz all talkin this of a stock gsr motor? vs a stock ls motor? Wouldn't the ls be better? More boost and torque with a good bottom end. Any help would do thanks.
Old Sep 10, 2001 | 11:05 AM
b18bturbo's Avatar
Default Re: turbo LS or turbo vtec? (IgniteTeg)
boost vs boost
GSR vs LS
If you have the same boost on both motors the GSR will make about 20-30 hp more. The LS ofcourse in stock trim can take up to 10psi easily if the fuel system is upgraded with a good high pressure pump. The GSR on the other hand is prone to detonation at that boost level do to its compression ratio. Overall the GSR will make more pwr at the same boost level. The LS will catch up if boosted higher.
Old Sep 10, 2001 | 11:10 AM
JM Performance's Avatar
Default Re: turbo LS or turbo vtec? (b18bturbo)
basically the b18b is better because you can safely make more power.
Old Sep 10, 2001 | 01:18 PM
DIRep972's Avatar
Smarter than you
Default Re: turbo LS or turbo vtec? (00SilverLS)
well consider this, for the price of a B18C you can have a built B18B.. if u are plannin on making 350hp use the LS tranny
J.nguyen
Sep 5, 2005 04:02 PM
N2X0
Oct 13, 2002 05:01 PM
AznInvasion
Aug 23, 2002 05:13 AM
Audi A4
Jun 6, 2002 03:10 AM
Mr. Softee
Aug 12, 2001 11:04 AM
