Good base to mess with
Old Nov 11, 2003 | 08:14 PM
pwrofdrm's Avatar
Default Good base to mess with
Does anyone know if a 1997 Civic HX would be a decent car for some simple bolt on's and eventual swap? Or would it just be a waste of time? I dont know much about the Vtec-E, can someone help me out?
Old Nov 11, 2003 | 08:16 PM
SOHC_MShue's Avatar
Default Re: Good base to mess with (lax1185)
it would be alright for a swap. Boltons aren't gonna make much power with that motor. Maybe do a y8 head swap.
Old Nov 11, 2003 | 08:27 PM
The Internet Tough Guy's Avatar
Default Re: Good base to mess with (SOHC_MShue)
yeah the hx is designed mostly for fuel economy and emissions: not performance.
ok because you spelled it properly i'm gonna assume you know how vtec itself works.
the vtec-e system uses the first stage variant of vtec. it only opens one intake valve in the low rpms (below 2500 i believe), to conserve fuel for city driving. after that, both intake valves are bound together, and open for more midrange and top end power. it only has one low cam lobe, not a higher one, like the other vtec systems. so this isn't ideal for performance, but is really good on gas around town.
if you want to find out more http://www.howstuffworks.com is good (look up vtec), and there is a few links on there that go more indepth.
Old Nov 11, 2003 | 08:31 PM
2000blackgsr's Avatar
Default Re: Good base to mess with (jwn7)
https://honda-tech.com/zerothread?id=101349
Good thread to read if you are thinking about an HX.
Old Nov 11, 2003 | 08:52 PM
Default Re: Good base to mess with (96coupe)
hmm... that was a good read - until that one tard chimed in and ruined it.
so the hx isn't all that bad after all... its actually better than the ex!!!
so to answer your question, yes that is a good motor to do some boltons etc to. let it breathe, especially with an intake mani from a y8.
Xxcivic97xX
May 4, 2025 10:44 AM
TheMechanic84
Aug 23, 2011 04:58 PM
Redline96LX
29
Apr 11, 2006 11:53 AM
pelotudo
48
Mar 10, 2003 04:49 PM
sshaikh01
Jun 29, 2002 08:44 AM
