d16a6 in a hf, problem
Old Nov 11, 2003 | 06:51 PM
ITSTOCK's Avatar
Default d16a6 in a hf, problem
A guy locally is putting a crx si d16a6 engine into my 89 crx hf, he got the motor all bolted in and he says its throwing a code 15 and its not getting any spark. Now i know the problem has to be something with the motor or connections or something because it had spark with the hf motor. Now there isnt some special wiring that ha sto be done for the a6 in the hf is there? there both mpfi and obd-0 so it should all be the same. He tried switching dist's from the hf motor to the dist. but it still threw the code, anyone have any ideas? i need to get this car on the road asap so im not stuck driving this dsm anymore thanks
Old Nov 11, 2003 | 07:43 PM
sporkcrx's Avatar
Default Re: d16a6 in a hf, problem (ITSTOCK)
I'm almost sure the HF wiring is identical to the Si wiring? The only reason I'm not 100% sure is because I've never done the swap. Also, the HF and Si dists. should be the same. Does anyone know what the code 15 is?
Old Nov 11, 2003 | 08:06 PM
ITSTOCK's Avatar
Default Re: d16a6 in a hf, problem (sporkcrx)
ignition output signal.
Old Nov 11, 2003 | 09:02 PM
jlicrx's Avatar
did you use the HF engine wiring harness? they are not the same as Si
Old Nov 12, 2003 | 04:53 AM
ITSTOCK's Avatar
Default Re: d16a6 in a hf, problem (jlicrx)
si harness was used
peiku
Feb 21, 2006 03:10 PM
Rocky's_CRX
32
Oct 16, 2005 05:04 PM
tcwcrxhf
Jun 27, 2004 04:42 PM
I Gotta Question
Feb 11, 2003 10:18 AM
91HATCH
23
Oct 15, 2002 05:03 PM
