friends 95ls is having electrical probs need a lil help
Old Nov 11, 2003 | 05:04 PM
cjames235's Avatar
Default friends 95ls is having electrical probs need a lil help
ok i installed greddy guages in his car. i used a parking light switched source wire found in one of the guage cluster plugs. worked perfect and then about 3 days later ALL parking lights went out. all front corners, all rear lights, and all guage cluster lights as well as the greddy lights. the headlights still work and the brake lights still work just not any of the parking lights. we checked all the fuses and they are all good and so are all the bulbs (cus we replaced those too) my question is what could it be besides the fuses or the bulbs? could the parking light relay have gone bad just coincidentally after i put in the guages or do you think i did somethin wrong with the install? thanks for any help given
-chris
Old Nov 12, 2003 | 03:36 AM
JimBlake's Avatar
Default Re: friends 95ls is having electrical probs need a lil help (cjames235)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">... could the parking light relay have gone bad just coincidentally after i put in the guages or do you think i did somethin wrong with the install?</TD></TR></TABLE>Is there a parking light relay??
As long as you're sure the fuses & bulbs are OK, all that's left is wires, the switch, & the grounds. Since the front & rear parking lights use different grounds, I'd vote for something upstream. Are you SURE the fuses are OK? Where did you make the connection for the gauges? Could that have come apart?
Old Nov 12, 2003 | 03:39 AM
cjames235's Avatar
Default Re: friends 95ls is having electrical probs need a lil help (JimBlake)
i havnt actually looked at his car yet i was just seeing if any of you had experienced anything like this. maybe the wire i tapped into split in half or something inside the t-tap. thanks for the help and i guess ill just have to run through the list of things to check
JJGL-EF90
Feb 21, 2011 11:37 AM
mikeSMASHES
Feb 10, 2010 12:41 PM
Brycen
Sep 16, 2007 07:24 PM
808civic808
Sep 24, 2004 08:14 AM
