Accord w/ H22 swap running too rich? Prob?
Old Nov 11, 2003 | 04:30 PM
HybridAccord's Avatar
Default Accord w/ H22 swap running too rich? Prob?
my h22 accord is running too rich... will this be a prob? is it bad for your car?
Old Nov 11, 2003 | 04:31 PM
iam7head's Avatar
Default Re: Accord w/ H22 swap running too rich? Prob? (HybridAccord)
what is the ratio? when is it running rich?
what does your Wideband oxygen sensor say?
Old Nov 11, 2003 | 04:48 PM
Default Re: Accord w/ H22 swap running too rich? Prob? (iam7head)
i have a autometer air/fuel gauge.. i idle last bar rich and when i drive.. it goes all the way to mid bar rich.. and i have heard taht it cant be good for your car
Old Nov 11, 2003 | 04:49 PM
iam7head's Avatar
the target is the striometric(spelling i know), 14.7 to 1
but your a/f guage and the narrowband o2 sensor wont give you a truth reading anyways
Old Nov 11, 2003 | 05:02 PM
i know for fact taht i am running rich.. i have a turbo fuel pump .. so i am getting alot more fuel and i burn gas really fast.. my fuel pressure regulator is turned all the way down also.. so w/ me running rich as i am.. is this bad for my car/motor?
Old Nov 11, 2003 | 05:04 PM
iam7head's Avatar
nothing diamatic will happen to your car NOW
Old Nov 11, 2003 | 05:14 PM
what do you mean by nothing diamatic will happen to my car NOW? please explain
Old Nov 11, 2003 | 05:19 PM
xxmaxhardcorexx's Avatar
if it's a jdm motor, it will burn rich... assumming you are using the jdm p13
it's ok it wont hurt your motor at all, unless your rear bumper is coated black
by your muffler. then you got a problem.. a little rich wont hurt. too rich you
will **** up your rings in time. BTW AF gauges are not consistant.
Old Nov 11, 2003 | 05:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridAccord &raquo;</TD></TR><TR><TD CLASS="quote">i know for fact taht i am running rich.. i have a turbo fuel pump .. so i am getting alot more fuel and i burn gas really fast.. my fuel pressure regulator is turned all the way down also.. so w/ me running rich as i am.. is this bad for my car/motor?</TD></TR></TABLE>
oh **** i didnt read your post before.... whay are you running a turbo fuel pump?
if your not running a turbo you dont need it.. if you are boosting... @7-9 pounds
you still dont need a fuel pump.. explain more about your set up... you are prob over doing it.
Old Nov 11, 2003 | 05:38 PM
Default Re: Accord w/ H22 swap running too rich? Prob? (KeithTurbo)
i planned on running nitrous.. so i was told that i would need more fuel.. so i put in a fuel pump.. and that is the main reason i am running so rich.. and u say over time running too rich can blow my rings?
Old Nov 11, 2003 | 11:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridAccord &raquo;</TD></TR><TR><TD CLASS="quote">i planned on running nitrous.. so i was told that i would need more fuel.. so i put in a fuel pump.. and that is the main reason i am running so rich.. and u say over time running too rich can blow my rings?</TD></TR></TABLE>
yea if your bumper is super black like i said.. then in time yes your rings will go and you will get blow by.(oil) but your talking maybe a year or two.
if you are running a 255 pump thats way to high. you are going to lose power for daily driving with your pressure being that high. let me guess the lowest you can get your regulator is 50psi.... wich is way to high.. i would take that pump out
and run a FMU on a stock pump. this way when you spray the fmu will dump
the fuel you need, making up for the pump....this way you still have your power for daily driving..
Old Nov 12, 2003 | 07:33 AM
v4lu3s's Avatar
RTFM
the fuel pump if a 255 lph can be a high pressure or normal pressure unit.
the high pressure requires a good (NOT b&m crap) adjsutable regulator. a normal pressure 255 uses the stock fpr just fine.
what is your fuel pressure currently set at rigihth now?
Old Nov 12, 2003 | 08:39 AM
accordhybrid's Avatar
Default Re: (v4lu3s)
I have the teh walbro hp 255 with the stock regulator adn my pressure is at 43psi
Accordhybrid
Old Nov 12, 2003 | 08:05 PM
Default Re: (accordhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid &raquo;</TD></TR><TR><TD CLASS="quote">I have the teh walbro hp 255 with the stock regulator adn my pressure is at 43psi
Accordhybrid</TD></TR></TABLE>
43psi is not that bad, it's a little rich but nothing to stress,as long as your not 50 psi or higher your in good hands
Old Nov 13, 2003 | 04:43 AM
iakona's Avatar
he's got the same problem i do. fully built, but running the JDM ECU none-the-less. it is black, but not enough to get to the bumper. fuel mileage isn't great, but it isn't the worst either. I KNOW HOW YOU FEEL. i just picked up a V-AFC II and i'm hitting the dyno tomorrow...with a Walbro 255HP fuel pump and a B&M FPR. will let you know the outcome and what they say. but like everyone says, there isn't anything detrimental short term, but long term, the rings go and if you're going to shoot N2O, then that will accelerate whatever wear is going on.
Old Nov 13, 2003 | 01:12 PM
Default Re: (iakona)
my reg is turned all the way down.. but i dont have a guage to tell me how much pressure im running.. i have a 255 walbro pump
Old Nov 13, 2003 | 04:59 PM
Default Re: (HybridAccord)
i had this problem with my pump, when i first turboed my car.. i couldnt get the pressure under 55psi, switched regulators and even drilled a hole in the diphram
...you need to see what your pressure is
Old Nov 14, 2003 | 06:21 PM
v4lu3s's Avatar
RTFM
my helm manul states that normal PSI range for fuel pressure in a prelude is 47-54 psi with the vacuum hose disconnected. 43 psi is a good range since its a pretty standard testing pressure for fuel injector flow tests.
btw i runa walbro 255 lph high pressur epump on my civic ahtch with an h22a, and i am at 38 psi at idle....runs great!
Old Nov 17, 2003 | 04:35 AM
iakona's Avatar
yep i run the 255HP with a B&M and 42 psi. runs great too.
rick7639
Aug 21, 2007 03:46 PM
turbo-d
Feb 4, 2005 04:58 PM
13secondmonster
May 14, 2004 07:23 AM
HybridAccord
Sep 21, 2003 10:22 AM
H22CIVIC
Jun 7, 2001 09:07 AM
