Did search can't find out what to do with these
Old Nov 11, 2003 | 04:17 PM
teknics1's Avatar
Default Did search can't find out what to do with these
Swapping h22a4 into 94 del sol si, wiring is done, shifter is done, but where do I hook these up to? they are on the back of the trans.
Old Nov 11, 2003 | 04:18 PM
Trooper's Avatar
Default Re: Did search can't find out what to do with these (teknics1)
Thoes are on the VSS right, if so just cap them off you dont need them
Old Nov 11, 2003 | 04:22 PM
teknics1's Avatar
Default Re: Did search can't find out what to do with these (Trooper)
VSS? Do I need to do anything else? Is there any fluid that goes through these lines, they were hooked into the steering rack on the prelude.
Old Nov 11, 2003 | 04:24 PM
Trooper's Avatar
Vehicle Speed Sensor is what it appears to be, just cap those off and you are set.
teknics1's Avatar
ok thanks
Old Nov 11, 2003 | 09:36 PM
hondaZvic's Avatar
thats weird.. i dont remember those tubes on my tranny.
Old Nov 11, 2003 | 10:42 PM
Newman's Avatar
New User
Those hook up to your power steering lines coming off of you rack, on your rear crossmember. If your car does not have power steering, just loop (close off) the hose so you close and seal the vacuum. If you have PS lines coming off of your rack, on your rear crossmember, connect the hoses to those lines.
'06-V6-MT
Jun 30, 2015 05:47 PM
Fred Demara
Jan 4, 2012 04:33 AM
dickie691986
Feb 16, 2010 03:35 PM
1993gsrcivic
Feb 8, 2009 07:20 AM
DAintegraGSR
Jul 19, 2005 10:16 AM
