put zc in my crx now idle is up and down ,up and down. why?
Old Nov 11, 2003 | 04:10 PM
civicracer1993's Avatar
Default put zc in my crx now idle is up and down ,up and down. why?
well i put a d16a1 integ motor in my 89 si , all sensors are plugged in and i have the right ecu for that motor but my idle is no lower than 2K and after drivin the car for a lil the idle keeps going up and down by itself.. i replaced all sensors and it still does it. it stops if i unplug the TPS sensor but then it drives bad and the idle goes even higher// there are no vacuum leaks and the coolant was bled three times so what could this be? it happened when i had my single cam too when i put a diff mani on it but then it stopped. any ideas?
Old Apr 2, 2004 | 07:40 PM
Full Race A6's Avatar
Default Re: put zc in my crx now idle is up and down ,up and down. why? (civicracer1993)
mine does the exact same thing, im stumped
Old Apr 2, 2004 | 08:10 PM
tdaccord's Avatar
check your throttle body gasket.
DumpdEJ6
12
Aug 4, 2013 05:16 PM
Ek4drcindy
10
May 18, 2011 04:13 PM
crx1.6i
Oct 5, 2006 09:27 AM
Full Race A6
43
Aug 11, 2004 03:06 AM
carsaregood
19
Nov 4, 2002 09:09 AM
