Need help with SRS Light
Old Nov 11, 2003 | 04:04 PM
MugenB16A2's Avatar
Default Need help with SRS Light
OK, here's the story:
I just recently did a swap into my EK-9 and I put a newer Steering wheels to replace the worn out one in my EK, well, I neglected to disconnect the battery and/or the ECU when doing this. Well, after the swap was completed, The SRS light was on, and I couldn't figure out how to correct it. I took it to the Local Honda dealership, but they couldn't reset it because the car had a different engine and ECU than factory, whatever. Is there anything I can do to correct this????
BTW, I did resolve the problem temporarily by taking the Si cluster apart, and removing the SRS light bulb, which I have no problem with at all, BUT, I may very well be purchasing a Spoon EK Cluster very soon and I do't know if it is equally as easy to take apart and remove the SRS bulb out of the Spoon one as well.
Any suggestions???
Old Nov 11, 2003 | 04:51 PM
ArinX's Avatar
Default Re: Need help with SRS Light (MugenB16A2)
well its just as easy to take the bulb out of the spoon one as well. My friend had the same problem, i think i still have some info on resetting the SRS light at my dads shop il try to get ahold of it.
Old Nov 11, 2003 | 05:31 PM
MugenB16A2's Avatar
Default Re: Need help with SRS Light (ArinX)
thank you ArinX
Old Nov 30, 2003 | 12:51 PM
salbaje's Avatar
here is the instructions to reset srs light
https://honda-tech.com/zerothread?id=264288
Old Nov 30, 2003 | 03:34 PM
G-money's Avatar
Default Re: Need help with SRS Light (salbaje)
just dont plug in the yellow clip in back of the cluster...thats the srs light...easy
eaz_e
Aug 19, 2008 04:00 PM
scarsofterroreg
13
Feb 1, 2008 06:28 PM
volkdlr
Nov 8, 2004 09:26 PM
MugenB16A2
Nov 11, 2003 05:27 PM
