Need help with SRS Light
Old Nov 11, 2003 | 04:03 PM
MugenB16A2's Avatar
Default Need help with SRS Light
OK, here's the story:
I just recently did a swap into my EK-9 and I put a newer Steering wheels to replace the worn out one in my EK, well, I neglected to disconnect the battery and/or the ECU when doing this. Well, after the swap was completed, The SRS light was on, and I couldn't figure out how to correct it. I took it to the Local Honda dealership, but they couldn't reset it because the car had a different engine and ECU than factory, whatever. Is there anything I can do to correct this????
BTW, I did resolve the problem temporarily by taking the Si cluster apart, and removing the SRS light bulb, which I have no problem with at all, BUT, I may very well be purchasing a Spoon EK Cluster very soon and I do't know if it is equally as easy to take apart and remove the SRS bulb out of the Spoon one as well.
Any suggestions???
Old Nov 11, 2003 | 04:04 PM
2000blackgsr's Avatar
Default Re: Need help with SRS Light (MugenB16A2)
So you haven't reset the ecu at all? Might want to try that.
Old Nov 11, 2003 | 04:05 PM
MugenB16A2's Avatar
Default Re: Need help with SRS Light (96coupe)
I tried that, I disconnected the battery and teh ECU, but it still comes on, won't turn off.
Old Nov 11, 2003 | 04:09 PM
This link might help
https://honda-tech.com/zerothread?id=264288
Old Nov 11, 2003 | 05:27 PM
seek167's Avatar
spoon cluster is the same as the si
Civic-Kids
Oct 2, 2009 03:08 PM
b20vtecturbe
Jul 2, 2009 07:21 AM
volkdlr
Nov 8, 2004 09:26 PM
MugenB16A2
Nov 30, 2003 03:34 PM
jhortillano
May 29, 2002 12:06 PM
