D15b wiring
I didn't have an si to begin with I had a Dohc zc and the intake doesn't bolt up(I tried) same with the dizzy. and it didn't come with a wiring harness I bought one from a 95 civic.
you should be be able to use the d15b's intake, the dizzy will require some modding to bolt on, not all of the leg will bolt on, you could of still used your present wiring harness instead of buying the 95 civic, if the 95 civic has vtec, you might still be able to send off your current harness and the vtec harness and get the (whatever you have dx or si -> b16), since all plugs from 85 -00 are al the same except when you have to add the vtec sensor, soleniod, oil pressure sensor, for use on the new motor.
Okay nevermind the whole thing, I just found a shop here in wichita that can to it for me for not so much $$$
I HATE WIRING!!!!
I HATE WIRING!!!!
