mini-me timing advise
Old Nov 11, 2003 | 03:08 PM
** OF HAZARD's Avatar
Default mini-me timing advise
i got it running but it runs ruff!! Any tips?
Old Nov 11, 2003 | 03:25 PM
91civicEX's Avatar
which head did you use? did you advance the cam gear 5 degrees? the z6 head is 5 degrees off of stock timing. advancing it 5 degrees will put the timing to 0
Default Re: mini-me timing advise (****S OF HAZARD)
TTT i need help!!
Old Nov 11, 2003 | 03:39 PM
I used a Y8 head... sorry!
The set-up:
Y8 head
d15b bottom end
Ls injectors
Ls throttle body
B&M fuel pressure regulator
those are the only things that should matter, I have more goodies but not neccesary.
Old Nov 12, 2003 | 05:56 AM
ttt
Old Nov 12, 2003 | 09:11 AM
once again!!
builtsinglecam
Oct 3, 2011 03:59 PM
cjwarren4dcivic
Feb 26, 2006 12:34 PM
roycivic92
Jan 21, 2005 03:30 PM
