DONT BUY GOD SPEED TEST PIPES !!!!!!!!!!!
I purchased a God Speed test pipe about 2 months ago and I have to say I am really dissappointed, here is why:
1. The test pipe was about 2 inches too long. This causes the
exhaust system to be pushed out, which makes the pipe hit
areas it shouldn't be hitting. And this is suppose to be the
new design, God speed says.
2. Because the o2 sensor is sitting so high it has to be turned on
its side. Then your o2 senor wire is really barely in there.
3. Lastly the check engine light doesn't come on for a while then
something happened. The catalytic material broke and
eventually broke into more pieces. Then my check engine light
on.
4. God speed said he would mail me another cat piece, but never
did.
5. The test pipe took over 3 weeks to deliver.
on.
did.
um... i think gods pipes are supposed 2 b used with a jdm header man.... that's probably y none of ur **** fits right....
dont flame me if im wrong... just tryin 2 help....
Kikko - doesn't his sig say spoon exhaust manifold, last time I checked spoons header was JDM and exhaust manifold meant header
sorry for the flame. BlkTypeR you should go for a custom cat instead - you really don't need to have a test pipe do (just thinkin about our environment)
[Modified by 2000-4DRGSR, 6:49 AM 9/10/2001]
sorry for the flame. BlkTypeR you should go for a custom cat instead - you really don't need to have a test pipe do (just thinkin about our environment)[Modified by 2000-4DRGSR, 6:49 AM 9/10/2001]
