gsr brake conversion problem
Old Nov 11, 2003 | 01:20 PM
Mr.E.G.'s Avatar
Default gsr brake conversion problem
i have a 94 civic cx hatch and i just did a gsr rear brake conversion. i inspected all of the peices before the install and compared to my factory stuff and i did not notice any thing that was bent.
but on my driverside rear i have negative camber which is not such a bad thing, but none the less it was not there before.
and on my rear passenger side i have really bad positive camber (there ain't nothin positive about it)
i know that it needs an alignment because my caster is a little screwy but the camber on the passenger side is way the **** off.
Like i said nothing looks bent. the only thing that i could think of is that possibly the the upper control arm (the one right above the hub) was some how different than my stock one. so i switched it out with my stock upper arm and the result is exactly the same. i also measured both and they are exactly the same dimensions
the only other possibility that i am aware of is that the junkyard that i got the parts from, for some reason may have put a civic upper arm on the integra rear trailing arm, but only on the passenger side. therefore resulting in a difference in upper arms between my driver and passenger side that ultimatley caused my camber to go to ****.
and when i swapped my factory upper arm i was just trading one civic part for another, instead of an integra for a civic.
the only way that this theory is possible, is if there is in fact a difference between the integra upper mount and the civic upper mount.
so the question of the day is ..... IS THERE A DIFFERENCE BETWEEN CIVIC AND INTEGRA REAR UPPER CONTROL ARMS???
Old Nov 11, 2003 | 02:56 PM
Lord Helmet's Avatar
Default Re: gsr brake conversion problem (Mr.E.G.)
92-up civic
94-up integras
same rear upper control arms. I measured it when I did my rear disc conversion.
Old Nov 11, 2003 | 06:20 PM
kommon_sense's Avatar
Default Re: gsr brake conversion problem (sleeperciv)
did you keep your stock lcas?
Old Nov 11, 2003 | 06:41 PM
blueeg's Avatar
u need the lcas?
Old Nov 11, 2003 | 09:19 PM
Mr.E.G.'s Avatar
what is an lcas
Old Nov 11, 2003 | 09:21 PM
Hybrid96EK's Avatar
Default Re: (Mr.E.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">what is an lcas</TD></TR></TABLE>
Lower Control Arm
Old Nov 11, 2003 | 09:22 PM
=GAME='s Avatar
lower control arms
edit: n/m
Old Nov 11, 2003 | 09:26 PM
Sprfreek's Avatar
just use your stock traininlg arms ... don't use the integra ones .. there bent .. no matter how they look there bent .. i went hough the EXACT same thing ... just change over the spindles and everything else that you need for the brake change
singlehx
Sep 12, 2009 09:04 PM
anothersickhatch
Suspension & Brakes
10
Feb 5, 2007 10:48 AM
anothersickhatch
10
Jan 28, 2007 11:43 PM
Bseriescivic5
18
Jul 13, 2004 06:30 PM
