camshaft seal?
Old Nov 11, 2003 | 01:07 PM
Donkey85's Avatar
Default camshaft seal?
Hello guys i'm getting this very annoying oil leak. I dont know where it is comming from. I've changed my oil pan gasket, that didnt fix it. Its not the rear main seal because the clutch is working fine and dosent slip due to oil. What i was wondering is if the camchaft seal is leaking would that cause the noticeable size oil leak? Also what side of the motor is the seal located on, how hard and what is needed to change the seal? thanks in advance
Old Nov 11, 2003 | 01:24 PM
USDM 4G VTEC's Avatar
Default Re: camshaft seal? (Donkey85)
is the rear main seal leaks it doesnt nesesary wil get on the clutch
u can tell by wetness comming from between the tranny and engine by oil pan and dust pan
for the cam seal , it is on the side of engine by the cam gear u have to remove cam gear to get it it
unless u got a front crank seal leaking also
Old Nov 11, 2003 | 02:14 PM
mattb16a1civic's Avatar
isnt there also another seal from the plug at the other end of the cam gear, and in a very rare instance the little o ring on the distributor could be bad, also there is an o ring on the oil pump and also on the vtec solenoid(if you have vtec, just thought that I coudltn remember which engine you stated)
Old Nov 11, 2003 | 02:21 PM
Xgen's Avatar
Default Re: (mattb16a1civic)
what he said ^^^^^
there are 2 seals on the camshaft, one is on the side of the cam gear, and you will have to take the cam gear off to replace it, (this seal goes bad in most D series engines)
and the other seal is on your distributer.
Old Nov 12, 2003 | 09:44 AM
Donkey85's Avatar
Default Re: (honda_guy_83)
well being that i have a JDM motor when i go to the dealer to get the seals what motor will i want to get them for? i have a 1992 JDM D15 non VTEC while the car is a 1989 hatch thanks
Old Nov 12, 2003 | 09:59 AM
Outsane's Avatar
Default Re: (Donkey85)
clean your engine so you can find out where the leak is coming from..
Old Nov 12, 2003 | 02:49 PM
yea thats what I would do also.
Old Nov 13, 2003 | 06:28 PM
Xgen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">well being that i have a JDM motor when i go to the dealer to get the seals what motor will i want to get them for? i have a 1992 JDM D15 non VTEC while the car is a 1989 hatch thanks</TD></TR></TABLE>
i imagine that a USDM seal would work on a JDM engine, but i am not 100% sure. but i guess as long as its a D series seal is should fit.
Old Nov 13, 2003 | 06:33 PM
Rywire's Avatar
I would order it for a usdm d15, or 16. Ryan
Old Nov 14, 2003 | 09:42 AM
Donkey85's Avatar
Default Re: (droppedcrxsi)
where is the front crank seal loacted????? i located the one cam seal behind the cam gear. also i am still confused about the other two. is there like an o-ring on the distributor? to be considered the other seal? then the front crank seal
Old Nov 14, 2003 | 12:09 PM
Rywire's Avatar
There is a crank seal on both sides of the crank. One under the pulley, and another under the flywheel. Yes, there is a distributor seal o ring. Pull the dizzy out, and it is at the tip. You dont have vtec, right? cause there is a leak prone seal under there too. Ryan
Ps, seeping headgaskets are kinda common too. Its not a big deal, just messy. Keep a eye on these leaks though.
Old Nov 14, 2003 | 02:38 PM
slooogsr's Avatar
just to give u an idea,
one of my camshaft seals is leakin on my zc, oil gets on the timingbelt and shoots all over the inside of my hood, black lil splatters all over the place........ i just keep an eye on the oil level but it doesnt leak enough to make a puddle
Tong.Y
Jul 4, 2011 08:16 PM
delprad
Nov 21, 2007 11:10 AM
shawty123
Jul 4, 2007 11:14 AM
svacca1
Nov 16, 2006 04:14 PM
brixity
Apr 10, 2005 08:17 PM
