Camber Kit
Old Nov 11, 2003 | 11:32 AM
AssPenny's Avatar
Default Camber Kit
Ok, since im getting some new coilovers soon, I'd figured I'd start looking at some camber kits. I did a search and only came up with a few things:
Ingalls front kit sucks
Skunks slip and don't keep adjustment
King is expensive and looks like it'll slip like the Skunks
There was another kit where it had a threaded A-Frame but i can't find it.
What do you all think would be the best to get? Just get the Skunks and rig something up so they don't move (I can machine a bracket to stop it from sliding maybe)?
As for the rear, i'm just going to get the ingalls since I don't like washers.
Old Nov 11, 2003 | 11:33 AM
Chris N's Avatar
Default Re: Camber Kit (AssPenny)
Get the skunk2 and replace the parts that slip (wai did this, others have too) and maybe reinforce like ed/sackdz did.
Old Nov 11, 2003 | 11:37 AM
Cosworth's Avatar
How low are you gonna drop the car? If it's 1" or less you don't need a camber kit. Just rotate regularly and the wear isn't bad at all.
Old Nov 11, 2003 | 11:40 AM
AssPenny's Avatar
Default Re: Camber Kit (Cosworth)
****, maybe 1" from the ground
Not sure exactly how low, was going to get it to where I like the way it looks, then throw it on some scales and balance it out. I was just thinking ahead. I had my old GSR lowered and I only put rear camber kits and everything wore even. Just looking into all my options.
Old Nov 11, 2003 | 11:50 AM
sackdz's Avatar
I stole Will's idea and installed some extra measures past the ordinary to keep the BJ's from slipping. Hopefully his **** will let the cat out of the bag so I can post a pic
sack-who wishes many happy BJs for everyone.
Old Nov 11, 2003 | 11:51 AM
Cosworth's Avatar
For the rear, you can always do the cheap washer trick.
IM Kengs and see if there are quality camber kits from JDM land. The U.S. camber kits always have to be messed with to make it work properly... which is pretty gay, if you ask me.
Old Nov 11, 2003 | 11:52 AM
Opie's Avatar
Don't most R's(at least the ones I have seen) have rear camber problems? Ie positive camber in the rear?
Positive camber looks = Same phenomenon witnessed by any one who has ever sat behind me and seen my desk, chair etc giving out from under me! Right?
Old Nov 11, 2003 | 11:55 AM
sackdz's Avatar
Coyne- what rates did you order? Unless you totally slam the car you won't need kits, the negative camber is a good thing. Or are you looking for somthing to play with at the tracK??
Old Nov 11, 2003 | 12:02 PM
AssPenny's Avatar
Default Re: Camber Kit (sackdz)
I'm going with 9k front and 11k rear (90% sure).
As for the camber, I want something to play around with on the track eventually, but for now I want something that won't make my tires wear out fast and look like crap (ie 80% of lowered hondas around here).
Old Nov 11, 2003 | 12:06 PM
sackdz's Avatar
All you need to do is align the toe. I'm gonna guess you'll be aroun -2* to -2.2* all around, and thats fine, no bunk tire wear from that, unless you don't set the toe...
AssPenny's Avatar
Standard alignment can set the toe? Last time I went to acura for an alignment they did not even list the toe on the alignment sheet.
EDIT: I could be wrong, it might have been caster, I know it was missing something.
Old Nov 11, 2003 | 12:07 PM
Chris N's Avatar
Toe is the only thing adjustable on the stock suspension.
Old Nov 11, 2003 | 12:10 PM
Johnny Tran's Avatar
Craig....time for you to enter a spelling b33 my friend.
Again, I can hardly believe all your sentences have no improper spelling.
Old Nov 11, 2003 | 12:13 PM
Flux's Avatar
Default Re: Camber Kit (Chris N)
I have the Skunk2 front kit and the Ingalls rear kit and have had no problems....
Old Nov 11, 2003 | 12:14 PM
AssPenny's Avatar
Default Re: Camber Kit (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote">Craig....time for you to enter a spelling b33 my friend.
Again, I can hardly believe all your sentences have no improper spelling. </TD></TR></TABLE>
Screw you guys I made it a goal a while ago to try and take my time and spell better and form better sentences (gramatics). I really wish I would have paid attention in english class instead of always sleeping off my hang over in the back of class.
Old Nov 11, 2003 | 12:15 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
Screw you guys I made it a goal a while ago to try and take my time and spell better and form better sentences (gramatics). I really wish I would have paid attention in english class instead of always sleeping off my hang over in the back of class.</TD></TR></TABLE>
whoa. no spelling errors. no grammar issues, i don't think.
Who are you and what did you do with Craig??
Old Nov 11, 2003 | 12:16 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">Get the skunk2 and replace the parts that slip (wai did this, others have too) and maybe reinforce like ed/sackdz did.</TD></TR></TABLE>
There was a post in the RR forum about Skunk2 releasing a new or revised kit to eliminate *slip* issues, it was made by Ghettoracer I believe.. might wanna try diggin that up
Old Nov 11, 2003 | 12:18 PM
Chris N's Avatar
Default Re: Camber Kit (DsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DsR &raquo;</TD></TR><TR><TD CLASS="quote">
There was a post in the RR forum about Skunk2 releasing a new or revised kit to eliminate *slip* issues, it was made by Ghettoracer I believe.. might wanna try diggin that up </TD></TR></TABLE>
I know for sure that Wai has simply replaced the suspect bolts/washers with no problems. I'd probably just do it that way, or will do it that way...
Old Nov 11, 2003 | 12:25 PM
py1188's Avatar
I currently do not run any camber kits, front or rear, and my car sits pretty low I ould say...not slammed, but pretty low. I say just get a quality alignment and rotate reglarly and you should be fine. That is if tire wear is all you're concerned with.
If you feel the need to test out certain camber settings than feel free to do so
Old Nov 11, 2003 | 12:27 PM
Tell Craig (whom ever you are) we want him back...
BAN!!!!!
Old Nov 11, 2003 | 12:29 PM
Chris N's Avatar
FWIW, i plan on getting F/R camber kits when i get the JICs. I'd rather have some adjustability after spending $$$ on suspension and get it right the first time.
Old Nov 11, 2003 | 12:36 PM
AssPenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">FWIW, i plan on getting F/R camber kits when i get the JICs. I'd rather have some adjustability after spending $$$ on suspension and get it right the first time.</TD></TR></TABLE>
Thats what I'm saying
Old Nov 11, 2003 | 12:37 PM
Chris N's Avatar
Thats what I'm saying </TD></TR></TABLE>
yep.
talk to wai or bob or whatevr his name is about what to replace on the skunk2 armz.
Old Nov 11, 2003 | 12:38 PM
AssPenny's Avatar
I got the low down from Sac on that one.
Now it's just a waiting game till thouse JIC's come
Anybody have a good deal on Skunk2 front camber kit? Preferably an Expo sponsor?
Old Nov 11, 2003 | 12:40 PM
Chris N's Avatar
Kyle sells them for pretty cheep.
