B16a2 Driver side mount swaped to a B18b1 Need advise
Old Nov 11, 2003 | 11:13 AM
length's Avatar
Default B16a2 Driver side mount swaped to a B18b1 Need advise
On my integra B18b1 swap i needed to change the driver side motor mount to fit. The mount that is actually on the Motor that has the two studs on it needs to be changed. The mount that i have is for a B16a2 (the mount on the car w/rubber bushing). Will the mount on the side of the engine from a B16a2 fit on a B18b1 block.?
P.s. The mount goes in and under the timing belt cover. Has three bolts two on top and one under the others. thanks for the advise need info quick.
Bump
Old Nov 11, 2003 | 12:00 PM
pennies_hatchie's Avatar
Default Re: B16a2 Driver side mount swaped to a B18b1 Need advise (Jdm Ek Hatch)
it should...
that's what all ek b-series hybrids have to do to make the b-series fit into their car
JohnnyWash1
Mar 13, 2009 08:46 PM
hondayute
Nov 13, 2007 08:47 PM
ekfighter
Sep 18, 2004 03:05 PM
Odiedogcx
Dec 18, 2003 09:41 AM
