any tips for replacing front oil seal?
Old Nov 10, 2003 | 09:00 PM
GSR44's Avatar
Default any tips for replacing front oil seal?
i'm gonna be changing the oil seal on my gsr tomorrow and i was wondering if there was anything i should look out for while replacing it. i'll also be replacing my timing belt since i gotta take off the old one (about 70,000+ miles) anyway. any other suggestions or tips? TIA.
Old Nov 11, 2003 | 12:04 AM
King_j's Avatar
Default Re: any tips for replacing front oil seal? (GSR44)
heat and power tools, you'll need these to remmove the crank pulley bolt. since you are replacing the t-belt, what about eh water pump, tensioner, and cam seal. that is of course if these need replacing.
the oil pump seal/front oil seal is kinda tricky. you have to pry it out, it is hard. when prying it out, be careful not to scratch the housing of the seal. use a small flat head screwdriver and pry from the middle of the seal.
when installing the new one, get a deep socket that fits snugly into the seal housing. align the seal, put teh socket behind it, and give it a few light taps. once you know it has seatted correctly, tap it more.
one tip would be to measure the length from teh seal to the outer edge of the housing on the old seal before you remove it, in this way you can compare this measurement to the new seal. then you know if it is in all the way.
good luck
Old Nov 18, 2003 | 10:18 AM
david90's Avatar
so the seal doesn't snap in when it is completely in?
Old Nov 18, 2003 | 11:03 PM
deepgreengsr's Avatar
Default Re: (david90)
when its completley in it wpnt go any farther. and the outer edge will be flush with the block. Be sure to grease the inside of the seal before installing or else its leak time.
Old Nov 22, 2003 | 05:41 PM
david90's Avatar
how much force is req to push the seal in?
Old Nov 22, 2003 | 07:15 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">how much force is req to push the seal in?</TD></TR></TABLE>
not that much, small taps until it's flush and align with the block.
also I wouldn't use a screwdriver to get the old seal out(too much of a chance on gouging the surface of the block). go to sears they sell the oil seal puller. cost about $5-$8.
88CRX_SiR
Apr 5, 2015 03:17 PM
DA STRIKER
Feb 19, 2011 02:38 AM
Racermech
Oct 24, 2006 03:21 PM
snatch
12
Mar 15, 2005 10:12 AM
