Good track times? 14.4 w/ skunk manifold
Whats up guys, i want to see what GSR's normally run with I/IM/H/E.
On sunday at MIR i ran a 14.4 @ 96mph w/ 2.3 60ft time
mods are:
Apexi i/h/e
skunk 2 manifold
clutch/lightweight fly
15 inch shitstreams on Azenis
the rest is wieght reduction
mods are:
Apexi i/h/e
skunk 2 manifold
very good times for those mods. chop down your 60ft time and you'll be even lower.
still running stock gsr cams, stock head, stock cam gears?
if so, very impressive
...you've got a very strong motor under the hood of your car
here's the list of the weight savings:
-no back seats/seatbelts/trunk mat/cardboard
-no spare tire/jack
-no spoiler
-no airbags
-no antenna motor (s2k antenna)
-no rear wiper/motor
-replaced driver seat w/ sparco seat
-aftermarket intake manifold/header/exhaust/flywheel replaced heavy OEM pieces
-aftermarket non-power mirrors
-CF hood
-no cruise control (1.5lbs
I'm pretty sure I could have dipped into the 14.2s, my 60ft times were bad and I haven't changed my spark plugs for about 15k miles. I think this proves that GSRs are capable of quick times with just "bolt ons", you just need a driver to guide it there.
-no spare tire/jack
-no spoiler
-no airbags
-CF hood
)I'm pretty sure I could have dipped into the 14.2s, my 60ft times were bad and I haven't changed my spark plugs for about 15k miles. I think this proves that GSRs are capable of quick times with just "bolt ons", you just need a driver to guide it there.
My new goal is to install Hondata, get it tuned, get new plugs/oil change and BFGs, (maybe new header/exhaust if the price is right), then hopefully break into 13's with no internal work at all.
The car is stock internals, the head has never been removed, only the valve cover has been changed.
post a slip please 2.3 is an pretty bad 60 foot, while trapping 96mph? plus you are still using the stock p72 with that manifold? if anyone on here knows the stock gsr ecu plain sucks on the skunk/itr manifold you hit a pure dead spot before switching over vtec.
https://honda-tech.com/zerothread?id=640707
I'll try and get the slips, and post them up.
Here is the make up of my other runs though
14.5 @ 96mph, 2.3 60ft (launched too low, rev limiter in second)
14.7 @ 96mph, 2.6 60ft (horrible track conditions, tires too cold, had to let off throttle until 6k to get traction)
ya.. i'd say GOOD TIMES!! s2k times for sure!!
thing must pull hard up top!!
congrats.... i wish there was a track open locally so i can test my new bolt-ons!
I'm hoping for approx. same times after i get some good tires!! :D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black sohc civic »</TD></TR><TR><TD CLASS="quote">plus you are still using the stock p72 with that manifold? if anyone on here knows the stock gsr ecu plain sucks on the skunk/itr manifold you hit a pure dead spot before switching over vtec.</TD></TR></TABLE>
1/4 mile wise the ECU isn't THAT bad, if you launch and shift the right way you should never be out of VTEC in the 1/4 mile.
I was running 22psi on the azenis, should have gone lower
Nice mph, nice times, good news is you still have room for imrovement on those 60 ft's so better times with more practice.
What kidn of burnout, tire pressure?
From what ive gathered the guys runing 2.0-2.1 on azenis are running about 18-20 psi, small burnout, just to clean off debris, and then its all driver.
Before every run I would spin the tires after dodgeing the water box to clear off all the debris, no burnout, just spin them for a sec or two. No water touched the tires except on the last run when the dumbass sparyed down the box as I was avoiding it. Tire pressure was a 22psi, should have been lower (shouldve, couldve, blah)
Nice times man. My gsr ran close to those time w/ a couple more mods. At the time mods were:
-AEM intake
-Comptech header
-Disconnected exhaust
-Comptech flywheel, stock clutch
-Comptech ECU
-Type R LSD
60'- 2.2
1/8 ET- 9.1
1/8 MPH- 76
1/4 ET- 14.2
1/4 MPH- 96
I had a little less weight reduction done than you and was running on 14" bald dunlop tires.
-AEM intake
-Comptech header
-Comptech ECU
-Type R LSD
60'- 2.2
1/8 ET- 9.1
1/8 MPH- 76
1/4 ET- 14.2
1/4 MPH- 96
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naturelovindc2 »</TD></TR><TR><TD CLASS="quote">Nice times man. My gsr ran close to those time w/ a couple more mods. At the time mods were:
-AEM intake
-Comptech header
-Comptech ECU
-Type R LSD
60'- 2.2
1/8 ET- 9.1
1/8 MPH- 76
1/4 ET- 14.2
1/4 MPH- 96
I had a little less weight reduction done than you and was running on 14" bald dunlop tires.</TD></TR></TABLE>
I want that LSD, it would definatly let me start touching 13s!
-AEM intake
-Comptech header
-Comptech ECU
-Type R LSD
60'- 2.2
1/8 ET- 9.1
1/8 MPH- 76
1/4 ET- 14.2
1/4 MPH- 96
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn »</TD></TR><TR><TD CLASS="quote">
I want that LSD, it would definatly let me start touching 13s!</TD></TR></TABLE>
No it wouldnt dummy.
