my car runs fine for 10minz.. then runs lean!!
Old Nov 10, 2003 | 05:51 PM
91integraLSVTEC's Avatar
Default my car runs fine for 10minz.. then runs lean!!
my car was running fine until i installed a new clutch (car has been sitting for 2 weeks) started it up runs fine for 10 minz then all of a sudden i see my air/fuel gauge drop down to lean when i floor it.. i also feel a differnce my car is much slower then before.. ive replaced the fuel filter and o2 sensor.. i have rc 320 injectors, aem fuel rail, b&m fp/gauge and vafc.. ive tried riching it up with my vafc and fuel pressure and still no luck.. has this happened to anybody?? damn and i was just about ready to dyno my car at secret service =o( (its been tuned with a vafc now i want hondata) really need some help trouble shooting this problem.. thanks!!
Old Nov 10, 2003 | 08:47 PM
VtecDA9's Avatar
Default Re: my car runs fine for 10minz.. then runs lean!! (91integraLSVTEC)
See if ur maintaining fuel pressure when you give it gas via the fuel pressure guage. Like my FPR, it wouldn't stay tight and it wouldn't hold pressure so i had to get a new one.
BTW, what have you done to your ls/vtec to reach 200whp..?
Old Nov 11, 2003 | 05:16 AM
Default Re: my car runs fine for 10minz.. then runs lean!! (VtecDA9)
it seems that my fuel pressure is the same at idle, ive reved it and such and still maintains its fuel pressure, but when i'm driving its a diffrent story.. theres no way i can see the gauge while i'm driving, so i do couple hard runs and pop the hood.. still maintains fuel pressure at 40psi. i think its something electrical because my car runs rich at cold start ups, then when it gets warm it runs lean =o( anybody else??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, what have you done to your ls/vtec to reach 200whp..?</TD></TR></TABLE>
the bottom end has usdm itr pistons, arpheadstuds/rod bolts new bearings and balanced.. the top end- b16a ported head, skunk stage 2 cams, manifold and jdm 4-1 header
Old Nov 11, 2003 | 07:32 AM
TGUNNER's Avatar
I had the same problem!! IMO You need to get a fuel pump. You def need a higer volume of fuel to flow if your using those injectors.
Old Nov 12, 2003 | 02:15 PM
Default Re: my car runs fine for 10minz.. then runs lean!! (TGUNNER)
well i just replaced my stock fuel pump with a walbro 255lph hp fuel pump and the problem still persist.. damn i guess nobody has this problem?? i suspect its an electrical problem but i dunno what =o(
Old Nov 13, 2003 | 05:20 AM
TGUNNER's Avatar
The only other thing I can think of is your using something like an autometer A/F gage. If this is the case, THEY SUCK!!! With all of the fuel upgrades you have there is no reason you should be leaning out. Set your timing to stock (15-16 degrees) IF the problem persists, tune with a wide band.
Old Nov 13, 2003 | 06:13 AM
cancer's Avatar
A/F guage are ****, get a wideband o2
Old Nov 16, 2003 | 09:16 AM
Default Re: my car runs fine for 10minz.. then runs lean!! (cancer)
narrowed down the problem.. 2 of my cylinders running lean.. probably dirty injectors.. i'll update after its cleaned
Old Dec 8, 2003 | 10:30 PM
sirminder's Avatar
So what was the problem? Did cleaning out the injectors do it? Im having a similar problem and need to pass the smog check due to running lean.
Old Dec 9, 2003 | 04:12 AM
Default Re: my car runs fine for 10minz.. then runs lean!! (sirminder)
sent the injectors out to rc yesterday, should have my car up and running by the end of the week..
Old Dec 16, 2003 | 05:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">So what was the problem? Did cleaning out the injectors do it? Im having a similar problem and need to pass the smog check due to running lean.</TD></TR></TABLE>
well i recieved my injectors, installed them, ran it on 60psi of fuel pressure.. as the result.. same thing 2 extremly rich, one extremly lean and the other has a fine mixture.. i'll probably take a picture of my spark plugs so you guys can see what i'm talking about.. so its not dirty injectors as i thought it was.. i'm starting to think its an ecu problem.. i'm taking my car to a mechinic on thursday hopefully he can find the problem.. does anybody have any other suggestions or hopefully somebody reading this had a similar problem?? thanks in advance
Old Dec 21, 2003 | 08:44 PM
cls6spd03's Avatar
could it be the o2 sensor..i have the same problem you do exactly. hey you live in orlando..hit me up..just moved back hom from there a year ago..moving to miami in a month. Bet i know you. let me know what you find out. it may help me
Old Dec 22, 2003 | 01:59 PM
94LS12bvtec's Avatar
Default Re: (cls6spd03)
My friends 3000gt was doing the same thing running rich at cold start and lean when he started driving andthe cause of his was a broke egr valve. I'm not sure if thats the same in your case but its worth a try. Peace
"This is what VTEC:honda2: sounds like!" God I love that quote
Help Me I need to be VTEC, anyone with a B16 or B18 Vtec head send me a price and maybe some pics
Old Dec 23, 2003 | 04:01 PM
cls6spd03's Avatar
Um just to let you know. I went to honda for my problem. It was leaning out because of a bad tps.. So i had to get a new t/b cause just like the map you cant just get that sensor. Got a ITR one like i had. was 750..but got it for 460. I have a hookup at honda here...employee cost. Ill let you know how it runs after.
Old Dec 23, 2003 | 07:21 PM
Highrevs99's Avatar
Does the plugs show leaner the farther you get from #4 . I had this problem and it was leaky injectors , or one was staying partial open causing #4-3 to show rich but #2 was normal and 1 lean as hell . I changed my Ecu at first thinking the same as you but the fix was a new set of injectors . Try taking the injectors and swapping them around .
Old Mar 1, 2004 | 08:46 PM
NC-B17A's Avatar
Default Re: my car runs fine for 10minz.. then runs lean!! (Highrevs99)
I have had a leaning problem around 3000-3500 for the last yr. in my B17.
I have changed the O2,IAT,coolent temp,270cc RC injectors,Walbro 255lph, fuel filter,new dist., map,tps, whole t-body, Tried a stock ecu.
I had a VAFC tried adding fuel with it. Removed Vafc. bumped fuel to 60psi.
I have moved the problem to 3500 now.
I have a p61 ecu with Hondata with 4% extra fuel at 3000+.
My EGT used to read 1200' before. it will get up to 1400' .
This is a N/A motor with 10.5:1cr
Old Mar 7, 2004 | 07:16 AM
Fork Sports's Avatar
Default Re: my car runs fine for 10minz.. then runs lean!! (NC-B17A)
i'm driving EG with b16b top, b16a bottom (ctr pistons) and e-manage.
i'm facing the same problem here since i put in the b16b top.
it happens when revving past 8000rpm on 2nd-4th gear (full throttle) - never tried 5th gear before,
the check engine will light up and the rev will cut instantly.
(my ecu does not have rev cut!)
if i continue driving with the check engine light on, the car will be running rich and a bit jerky but without power.
i have no idea what will happen if i were to rev it past 8000rpm again with the check engine light on.
also when non-stop driving (@ 4000rpm) for more than 30mins (low throttle),
my a/f meter will show lean mixture (maybe not 100% accurate but the loss in power is extremely obvious when it shows lean mixture)
tried retarding the ignition timing, still the same.
tried using colder plugs (ngk iritop 8) also didnt help either.
this problem has costed me 2 sets of iridium plugs!
i've changed to itr fuel pump and also changed another set of stock injectors,
even set the fuel to the max with e-manage.
i've also just changed my o2 sensor last year.
so i guess must be fuelling problem...
tps seems to be fine while monitoring from e-manage.
and what is EGR VALVE?
should i put in h22a injectors & 22a fuel regulator / h22a fuel pump?
i'm running on a tight budget here...
or just only install an adjustable fpr?
what pressure would be sufficient for adjustable fpr?
desperately need advice... thanks
colbynorwood
Jun 10, 2013 02:05 PM
GSlowR
Aug 16, 2007 07:12 PM
Unsung
Jan 27, 2003 07:37 PM
10seconds
Jul 15, 2002 02:00 PM
JM Performance
Dec 17, 2001 03:15 PM
